Are D-series and B-series FPRs the Same?
Old Sep 26, 2005 | 06:18 PM
Nisif's Avatar
Default Are D-series and B-series FPRs the Same?
Like the title says
Old Sep 26, 2005 | 07:24 PM
Nisif's Avatar
Default Re: Are D-series and B-series FPRs the Same? (Nisif)
Bump
Old Sep 26, 2005 | 07:34 PM
Sliced Beard's Avatar
yes, except for the bends on the return line and sometimes they have a different return line tubing size.
they all regulate between 38-43 psi and the computer adjusts injector pulsewidth from there
Old Sep 26, 2005 | 08:47 PM
Nisif's Avatar
Default Re: Are D-series and B-series FPRs the Same? (DirtySol)
Thanks man, my B&M fpr took a **** on me, so hopefully I can get the d-series oem fpr on there with no clearance issues.
Old Sep 27, 2005 | 07:58 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirtySol &raquo;</TD></TR><TR><TD CLASS="quote">they all regulate between 38-43 psi and the computer adjusts injector pulsewidth from there </TD></TR></TABLE>Not all Bs are the same. GSR has higher fuel pressure vs LS; but maybe all EXCEPT GSR/typeR would work?
Old Sep 27, 2005 | 08:12 AM
Default Re: Are D-series and B-series FPRs the Same? (JimBlake)
the GSR/R use a 43.2psi regulator. which is accurate between 2psi. You can still use it becasue your ECM will now the difference VIA your o2 sensor. IT MAY run a tad bit richer but not much to make a difference.......you may get a little soot built up at the bock of your car after a while.
I still say replace it with one from the same model vehicle just for tubing shape and diameter.
Old Sep 27, 2005 | 09:42 AM
mmuller's Avatar
Mad Scientist
yeah there is variations between fpr's, b17 one is the highest pressure i have seen for stock; but yeah, the ecu will compensate
M.A.R.C.
Mar 10, 2007 01:03 PM
M.A.R.C.
Jan 9, 2007 06:34 PM
finest_GSR
Oct 14, 2006 09:30 AM
debogsr
May 30, 2005 08:03 PM
turboser1
Dec 4, 2003 07:19 AM
