Important: which program to tune OBD0 with ITBs setup?? HELP PLS
Old Sep 29, 2005 | 10:33 AM
CRX-ZC's Avatar
Default Important: which program to tune OBD0 with ITBs setup?? HELP PLS
I have a fully built DOHC ZC engine with individual throttle bodies and OBD0 ECU. This way the ECU has to be tuned with TPS and not MAP sensor. My tuner said that in TurboEdit he could only tune it with MAP sensor - vacuum. Has anyone OBD0 ecu and individual thorttle bodies on his car? With which program can OBD0 ecu be tuned with TPS? Is there the only way to convert it to OBD1 ecu?
HELP ME, I HAVE A RACE ON SUNDAY!
Old Sep 29, 2005 | 12:10 PM
drdisco69's Avatar
Default Re: Important: which program to tune OBD0 with ITBs setup?? HELP PLS (CRX-ZC)
You have a race in three days and you haven't even picked an engine management system, much less tuned the car??? I wouldn't hold my breath on making that race...
To answer your question, it's possible to tune the ITBs using the map sensor, but it won't give as smooth and friendly a tune as with Alpha-N blending like Crome can do. For a functional setup, use TurboEdit, but for a really easy to drive car, convert to OBD1 and use Crome.
DA9lst
Engine Management and Tuning
Jan 30, 2011 04:52 AM
crxzcracer
May 9, 2007 04:00 AM
Cloner
Nov 26, 2005 09:24 PM
sanimalp
11
Sep 16, 2005 12:28 PM
