Ignition management
Old Sep 26, 2005 | 10:26 PM
iluvdrt's Avatar
Default Ignition management
I just had a few questions regarding ignition upgrades with a control box.
What I was thinking was like an MSD 6, or Accel Fireball, something to that nature.
When you use something like that on an 0BD0 vehicle, does it manage the spark instead of the ECM, or does it go inline with the ECM.
The reason I ask is because I have been having some major, possibly terminal issues with my stock Ign set up, and have spent well over $600 trying to replace stock parts, and harnesses. I need something that will work with little trouble, and in place of the ECM if possibble.
In case your wondering, I have an old Subaru wagon, with a new JDM turbo engine. I am asking here because most of the people on the old Subaru sites are fucktards, and have no clue what they are talking about.
Thanks.
Old Sep 26, 2005 | 10:40 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Ignition management (iluvdrt)
Bump for a good question. You got a pic of that Subaru you speak of man?
Old Sep 27, 2005 | 06:31 AM
iakona's Avatar
i believe those only alter teh spark. i had one on my old school '83 volvo and since it installs between the coil and teh spark plugs, that is the only thing it can mess with. and i never had any problems.
Old Sep 27, 2005 | 10:35 PM
iluvdrt's Avatar
Default Re: Ignition management (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">Bump for a good question. You got a pic of that Subaru you speak of man?</TD></TR></TABLE>
Anyone else? I have a MBC, TMIC, and everything ready to go. Imagine something like this running in the low 14's-high13's.
I have done A LOT of work to this car, and now I am stumped.
Old Sep 28, 2005 | 06:53 AM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iluvdrt &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
HAHAHAHA, that's ******* awesome!
Anywho, the ignition boxes take the trigger from the stock ecu, so it will have the same timing curve. They then add a lot more duration to the spark, in an effort to help with combustion.
There are aftermarket ignition control systems that allow you to do your own maps, some searching will yield results, if that's what you want.
Old Sep 28, 2005 | 07:38 AM
B6tPoweredMx3's Avatar
Default Re: Ignition management (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">
There are aftermarket ignition control systems that allow you to do your own maps, some searching will yield results, if that's what you want.</TD></TR></TABLE>
If you find that its your ecu giving you problems.
Megasquirt
Old Sep 28, 2005 | 10:07 AM
drdisco69's Avatar
Default Re: Ignition management (B6tPoweredMx3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B6tPoweredMx3 &raquo;</TD></TR><TR><TD CLASS="quote">Megasquirt </TD></TR></TABLE>
My thoughts exactly.
dantamparacer
Jun 28, 2012 03:46 AM
WILEY
Jul 13, 2007 02:31 PM
Iceman05
Jan 5, 2006 10:52 AM
reed857
Aug 1, 2005 12:56 PM
92HB_HB
Apr 15, 2004 12:50 PM
