Are crank shafts balanced with or without the pulley??
Old Sep 28, 2005 | 04:17 PM
sickerhatch's Avatar
Default Are crank shafts balanced with or without the pulley??
Im wondering if it will throw off the balance of my motor if i use a pulley that was not the original one from the motor?
Old Sep 28, 2005 | 04:26 PM
Chiovnidca's Avatar
Default Re: Are crank shafts balanced with or without the pulley?? (sickerhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sickerhatch &raquo;</TD></TR><TR><TD CLASS="quote">Im wondering if it will throw off the balance of my motor if i use a pulley that was not the original one from the motor?</TD></TR></TABLE>
No, it'll be fine.
Old Sep 28, 2005 | 04:36 PM
NJIN BUILDR's Avatar
Honda engines are balanced with out the pulley.The pulley is then balanced by it self.If the pulley you are going to use is out of balance it will make the engine out of balance.
Glenn
Old Sep 28, 2005 | 05:08 PM
Default Re: Are crank shafts balanced with or without the pulley?? (NJIN BUILDR)
cool thats what i wanted to know.
Old Sep 28, 2005 | 06:24 PM
doublejz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">Honda engines are balanced with out the pulley.The pulley is then balanced by it self.If the pulley you are going to use is out of balance it will make the engine out of balance.
Glenn</TD></TR></TABLE>
CRX_RR
Mar 17, 2008 06:56 PM
team 15
Jun 18, 2007 07:41 AM
duececoupe2
Feb 28, 2005 08:04 PM
RACING INTEGRATION
Jan 21, 2005 06:44 AM
japspecjohn
27
Nov 3, 2003 06:13 AM
