tranny play?? is this normal what are some tranny inspection methods???
o.k with the tranny off the engine, the shaft, when turning it clockwise then counter clockwise, you can hear/feel play in between the gears, but everything shifts ok, should i install this tranny this way cause my current LS one knocks (bad bearings)...
Mad Scientist
Re: tranny play?? is this normal what are some tranny inspection methods??? (Muckman)
you mean you can hear play when you move the input shaft back and forth? thats normal
Re: tranny play?? is this normal what are some tranny inspection methods??? (mmuller)
You should be able to spin the input shaft back and forth maybe 1/8th of an inch at max. What you feel is normal. Now... if it's side-to-side movement then you might be fooked.
