ls head compared to b20 head?
Old Sep 30, 2005 | 05:39 PM
mycrx7's Avatar
Default ls head compared to b20 head?
i have a b18a1 block needing a head, is a b20 head a better one for it? or is it about the same as a ls one.
Old Sep 30, 2005 | 11:50 PM
japan4racing's Avatar
cams are a bit different and teh combustion chamber may differ
Old Oct 1, 2005 | 05:58 AM
PogKai's Avatar
combustion chambers are equal. 81mm
Old Oct 1, 2005 | 12:50 PM
Slow ass EF's Avatar
Default Re: (PogKai)
b20 blocks are 84 mm.
ls, gsr and b16's all have the same 81mm bore
Old Oct 1, 2005 | 03:38 PM
slomofo's Avatar
GDD Member
Default Re: (slow *** ef)
Heads are the same, intake/exhaust manifolds are different, but just use your stock stuff.
Old Oct 1, 2005 | 06:21 PM
ALLMOTA92EG's Avatar
Well the b20 head has a 84mm combustion chamber so putting it on your ls block will lower the compression.
Old Oct 1, 2005 | 09:44 PM
mmuller's Avatar
Mad Scientist
Default Re: ls head compared to b20 head? (mycrx7)
Only the p8r head has an 84mm, it also has vtec sized valves.
the rest of b20 heads are 81mm, same p75 casting
Old Oct 2, 2005 | 02:13 PM
dfoxengr's Avatar
Default Re: ls head compared to b20 head? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">Only the p8r head has an 84mm, it also has vtec sized valves.
the rest of b20 heads are 81mm, same p75 casting</TD></TR></TABLE>
good- someone who knows what theyre talking about.
93-eghatch
Feb 6, 2021 01:26 PM
kaduku
15
Jul 3, 2009 07:54 AM
E_F_9
10
Feb 12, 2006 07:32 PM
SCIVIC94
Mar 3, 2005 06:57 PM
savestheday13x2
16
Oct 11, 2004 08:32 PM
