Craftsmen brake bleed vacuum pump?
Old Sep 26, 2005 | 08:16 AM
StatGSR's Avatar
Default Craftsmen brake bleed vacuum pump?
saw this a little while ago and it sounded like it could be a nice thing to have for bleeding brakes since you are susposed to be able to do it yourself with it. just wondering if anybody has used one, and how well it worked and how easy it was. thanks.
http://www.sears.com/sr/javasr...21000
Old Sep 26, 2005 | 09:15 AM
JimBlake's Avatar
Default Re: Craftsmen brake bleed vacuum pump? (StatGSR)
I've got one my MityVac, it looks a bit different but does the same job.
I'm not impressed for bleeding brakes, but its useful for diagnosing vacuum & solenoid valve problems.
When bleeding brakes by vacuum, air gets sucked in thru the bleeder valve threads. It gets better if you smear a big grease fillet around the base of the bleeder screw, but it still does it. When I get clean fluid (bubbles never quite stop) I quit using the vacuum bleeder. Then I finish up the normal way with someone pumping the brake pedal.
I got a pressure bleeder now... but I haven't actually used it yet.
Old Sep 26, 2005 | 12:30 PM
StatGSR's Avatar
Default Re: Craftsmen brake bleed vacuum pump? (JimBlake)
thanks jim, anybody else try this thing?
Old Sep 27, 2005 | 11:21 AM
StatGSR's Avatar
up
Old Sep 27, 2005 | 12:10 PM
Buzzbomb's Avatar
Like JimBlake, I also have the MityVac
I imagine that the Craftsmen one works the same. I know the frustration with the air bubbles coming through the threads. Even though it has that annoying feature, I prefer using the pump. I'm usually by myself when doing this stuff so it's more convenient for me.
They're nice to have for diagnostics.
Old Sep 27, 2005 | 12:54 PM
StatGSR's Avatar
Default Re: Craftsmen brake bleed vacuum pump? (Buzzbomb)
yea the craftsmen one says it comes with some sealant to prevent brake fluid bubbles....
Old Sep 28, 2005 | 04:16 PM
StatGSR's Avatar
anybody else got one of these?
Old Sep 28, 2005 | 04:39 PM
Tyson's Avatar
i dont recommend vacuum systems for bleeding brakes. ive used the mityvac and it did not perform well, and was quite tiresome pumping so long.
i recommend pressure systems that mount to the master cylinder instead.
but old fashion way is best. you can teach anyone to pump the brakes while you open the bleeder screw.
Old Sep 28, 2005 | 05:33 PM
StatGSR's Avatar
Default Re: Craftsmen brake bleed vacuum pump? (Tyson)
well thanks guys, actually a good friend of mine just showed me this http://www.speedbleeder.com/ looks like a lot better way too go, its even cheaper too...
Old Sep 29, 2005 | 04:59 AM
JimBlake's Avatar
I've tried speedbleeders too. They worked pretty good. Then 2 years later when I wanted to flush brake fluid again, the little checkvalve was rusty & it didn't work so hot.
Maybe in Fla or Az, but I got a feeling that they might use a little salt on the roads in MN...
Old Sep 29, 2005 | 07:17 AM
StatGSR's Avatar
hmmmm well they got those stainless steel ones too... for 15 each....
Old Sep 29, 2005 | 08:41 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StatGSR &raquo;</TD></TR><TR><TD CLASS="quote">... stainless steel ones too...</TD></TR></TABLE>Let us know how they are. Stainless weren't available when I tried them.
dank24
11
Apr 2, 2007 09:26 PM
JCracer723
46
Mar 17, 2007 01:14 PM
Mattyg2
Sep 15, 2004 06:41 PM
sil
May 5, 2003 11:31 AM
Lei Siew Long
Sep 30, 2001 07:08 PM
