CTR piston's and 404 cams
Old Sep 26, 2005 | 04:02 PM
spoonEGcivichatch's Avatar
Default CTR piston's and 404 cams
i was wondering i have CTR piston in a b18b block with b18b stock rods, and i am going to use 404 crower cams, and i was wondering if that is safe. what i mean is , is the lift and idration to high for these cams. or should i use another cam. i am really confused on this set up with ctr pistons, i also have a set of itr usdm pistons.
Old Sep 26, 2005 | 05:08 PM
projectTeG's Avatar
yes you should be fine, look up hybrid_vtec and i believe a few other members are runnung this. go and look on non-vtec.com and youll find tons of info
Old Sep 26, 2005 | 05:13 PM
Default Re: CTR piston's and 404 cams (spoonEG9civichatch)
thanks so much and also im going to use the b18b head and also wondering about piston to deckhieght am i ok there. ill check these other sites also, but mite not find so if someone knows here that would be great
Old Sep 26, 2005 | 05:15 PM
hybrid-vtech is using pr3 psitons those r si pistons right or are the b16b the ctr pistons
Old Sep 26, 2005 | 05:19 PM
projectTeG's Avatar
yea hes using -r3 which are jdm b16a pistons, the ctrs are the b16b, i forgot the user thats using the ctrs he said that he could advance his cams a long ways and not touch, but if your not sure the you could clay the motor during the build
Old Sep 26, 2005 | 05:48 PM
how do you clay a motor, never had to do it before and never heard of it
THUNDERCHUNKY
Jul 20, 2005 11:59 AM
dajman94
Jun 25, 2005 05:29 PM
LswithJg
May 21, 2003 08:16 PM
KC GSR
Jun 4, 2002 07:28 PM
