feed my b20 more fuel!!!
Old Oct 1, 2005 | 08:50 AM
BLUE EH3's Avatar
Help we my pennies
Default feed my b20 more fuel!!!
why am i running lean still. my AEM FPR is at 40psi, i have stock b20 with mild head work done. when i rasie it up im was backfiring at high rpm... any tips??
Old Oct 1, 2005 | 09:42 AM
mmuller's Avatar
Mad Scientist
Default Re: feed my b20 more fuel!!! (BLUE EH3)
upping fuel in the program?
what cams?
Old Oct 2, 2005 | 07:40 PM
VN712's Avatar
how do you know are you running lean?
Old Oct 3, 2005 | 07:38 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: feed my b20 more fuel!!! (B20ZLS)
the inpection station told i was !
Old Oct 3, 2005 | 09:42 PM
VN712's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">the inpection station told i was !</TD></TR></TABLE>
One option would be to find a crv manual ecu if you are obd2 that is.
A better one would be to chip your ecu and tune it with uberdata. I wouldn't think that it's that much of a difference between the LS and the b20 ecu with the 0.2 litre and considering the stock ls has a higher comp. ratio than the b20b.
Old Oct 3, 2005 | 09:47 PM
VN712's Avatar
I have a b20z in my integra. I never had a problem with it at high rpm.
Old Oct 4, 2005 | 02:51 PM
bemorfast's Avatar
what ecu are you using?
Old Oct 4, 2005 | 05:01 PM
Redsun's Avatar
Default Re: feed my b20 more fuel!!! (bemorfast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bemorfast &raquo;</TD></TR><TR><TD CLASS="quote">what ecu are you using?</TD></TR></TABLE>
Kenji ecu for my B20 12.5:1
Old Oct 4, 2005 | 06:47 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: feed my b20 more fuel!!! (Redsun)
p75
Old Oct 8, 2005 | 06:57 AM
PogKai's Avatar
turn up more the FPR psi
Old Oct 9, 2005 | 08:56 PM
BLUE EH3's Avatar
Help we my pennies
whats the diffecne on getting
FPR, bigger injectors, biger fuel pump?
Old Oct 11, 2005 | 01:58 AM
Redsun's Avatar
FPR allows you to raise the pressure at which fuel can reach in the system before being purged out.
Bigger injectors - common sense really.
Pump - supplying the fuel from your tank.
Old Oct 11, 2005 | 11:17 AM
sanimalp's Avatar
$cat /dev/urandom
isnt stock pressure on most honda's 45 psi? i know it is for sure on my ef hatch.. but i dont know for sure on anything else.
Old Oct 12, 2005 | 04:45 AM
BLUE EH3's Avatar
Help we my pennies
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redsun &raquo;</TD></TR><TR><TD CLASS="quote">FPR allows you to raise the pressure at which fuel can reach in the system before being purged out.
Pump - supplying the fuel from your tank.</TD></TR></TABLE> so what should i get next?
Old Oct 13, 2005 | 01:50 AM
Redsun's Avatar
Whats a p75?
Turn up the fpr first (i thought 45psi was stock?) and tune with that until you dont back fire.
Old Oct 13, 2005 | 04:36 PM
BLUE EH3's Avatar
Help we my pennies
p75 ls ecu
rexracer626
Jun 24, 2010 06:28 AM
iloveb16
Mar 28, 2007 08:04 PM
lowRIDAH
12
Nov 25, 2005 07:56 AM
1hotcivicSi
30
Feb 16, 2004 03:15 PM
blufke
Jun 19, 2002 10:20 AM
