low comp all motor...
Old Sep 25, 2005 | 04:53 PM
JeffRocksYoSocks's Avatar
Default low comp all motor...
My car used to be turbo and im running LS/vtec with 9:1 aries pistons, ported head, valvetrain, and now a stock p28. Anyone ever drive their car all motor with low compression pistons?
Old Sep 25, 2005 | 05:59 PM
Used2beAb16's Avatar
Default Re: low comp all motor... (JeffRocksYoSocks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JeffRocksYoSocks &raquo;</TD></TR><TR><TD CLASS="quote">My car used to be turbo and im running LS/vtec with 9:1 aries pistons, ported head, valvetrain, and now a stock p28. Anyone ever drive their car all motor with low compression pistons?</TD></TR></TABLE>
You wont make good power with that compression.
Old Sep 25, 2005 | 06:04 PM
mmuller's Avatar
Mad Scientist
its not all that bad; you wont be able to run big cams though. For mild power expectations it will work.
Old Sep 25, 2005 | 06:55 PM
well i dont plan to make power or anything i just want to have it running. you know still waiting for my other motor. Im going to be running the stock b16 cams. will that be chill? im just wondering if the motor will break or have problems driving it like that.
Old Sep 25, 2005 | 07:28 PM
non-VTEC's Avatar
it will run perfectly fine and you can run regular fuel too......save some $$$
it will be a little sluggish all over the RPM range but who cares really....
Old Sep 25, 2005 | 07:36 PM
2crxs's Avatar
I had mine rebuilt with 9:1 pistons about 3 months ago, ran out of money for turbo. 20 miles to work and back each day with no problems.(B16)
Old Sep 26, 2005 | 06:46 AM
Default Re: low comp all motor... (2crxs)
You may benefit from a retune, you can def get away with running more timing or cheaper fuel, and shouldnt have det. problems.
Stick with stock cams, any big cams that will drastically lower your dynamic compression is gonna hurt cuz you aint got the static to compensate.
Old Sep 26, 2005 | 12:02 PM
boost93's Avatar
I broke in my b18 with 9:1 compression before I put my turbo on and it ran like ****, no power whatsoever
boostfever
47
Oct 25, 2010 09:59 PM
.adam.
Dec 27, 2005 08:37 PM
IGotVTECyo
Jul 7, 2005 06:41 PM
-iLLuZioN-B18C1
Jul 27, 2004 02:46 PM
HondaCutter
Dec 9, 2001 01:25 PM
