b16a vs b16b
Old Dec 7, 2002 | 10:45 PM
cmodem's Avatar
Default b16a vs b16b
hey all just wondering what the diff between the two is. Wanted to get a spoon stroker for my b16a2 but they only sell stroker kit for b16b what's the diff will it fit?
Old Dec 7, 2002 | 11:04 PM
aeolus's Avatar
Default Re: b16a vs b16b (cmodem)
supposidely the b16b block is just like the b18c block.Which allows the b16b to use a better rod to stroke ratio because of the taller deck height.
Old Dec 7, 2002 | 11:18 PM
cmodem's Avatar
Default Re: b16a vs b16b (aeolus)
so do i need to be worried about clearance if i get the stroker kit since b16b has taller deck height? or should i just get a b18c since the stroker kit for the b16b makes it a 1.8L.
Kataku2K3's Avatar
You are right on... The B16B block is the same as a GSR/ITR.... It doesn't necassarily yield a R/S better than a B16A but just higher.. It's actually higher than you want, ~1.85 as the B16A has a near perfect 1.74... I love the B18C... It's near 1.6 R/S is perfect for me.. If you get a B16B block rip it's internals out and drop a GSR/ITR crank and rods into it... Then you got the cool B16B stamp with a 1.8L motor... I would sleeve it up to 85mm then you got a 1.98L motor... Good Luck in whatever path you take... Latez
Wytek9
Apr 23, 2008 09:32 AM
Chief Wenceslaw
13
Jun 24, 2006 05:03 PM
DC2 Mang
12
Mar 9, 2006 05:47 PM
EK Ferio
Oct 14, 2002 03:51 PM
DC2#309
Mar 25, 2002 08:38 AM
