B16 Block
Old Dec 6, 2002 | 01:29 PM
Fatty_1775's Avatar
Default B16 Block
Is the block the same on all B16's whether they are jdm, usdm, first or second gen?
Old Dec 6, 2002 | 01:40 PM
BudaKai's Avatar
Default Re: B16 Block (import_racer)
The emissions equipment are the differences between the JDM and the USDM blocks. The first and second have the same deck height that is shorter than the rest of the B-series. The third gen. or type-R have the same deck height as the rest of the B-series. Please correct me if I'm wrong, but that is all I can remember about the differences.
Old Dec 6, 2002 | 04:24 PM
Fatty_1775's Avatar
Default Re: B16 Block (tzsir)
I was just wondering because if my block is damaged on my second gen jdm b16, i want to know what I can do, either replace it or ls/vtec or crvtec. Is there alot of work needed to do ls/vtec or crvtec? Oh yeah, I am running boost also, I think that is how my engine got toasted.
Old Dec 6, 2002 | 04:26 PM
Kataku2K3's Avatar
The B16B block is the same as the GSR/ITR... which also has the same deck height as B18A/B, B20B/Z.....Peace
Old Dec 7, 2002 | 04:55 PM
Fatty_1775's Avatar
Default Re: B16 Block (JDMspecEG6)
So I can just swap the gsr or itr block with no mods?
Old Dec 7, 2002 | 07:49 PM
Kataku2K3's Avatar
Yea... if you are gonna run light boost i would just go with the GSR block.. There is no reason to get the ITR it's just go higher compression... If you build the motor then you can boost more... Latez
Old Dec 8, 2002 | 10:52 AM
BudaKai's Avatar
The B16b is actually the fourth generation of B16.
ygdraztik
Oct 19, 2009 05:15 PM
HEADS OR TAILS
Jul 26, 2009 09:29 AM
raiden571
Dec 22, 2008 07:35 AM
tteal ddx
Jul 13, 2006 04:14 PM
aser1z
Sep 20, 2005 01:29 PM
