Where to hook up MAP sensor for ITBs?
Old Dec 8, 2002 | 11:33 AM
Clayton's Avatar
H-T Administrator
25 Year Member
Default Where to hook up MAP sensor for ITBs?
Where do you hook up the vacuum line for the MAP sensor on the ITBs manifold? There's two ports for vacuum, but on looks like it's for a purge solenoid and the other looks perhaps to be for MAP... It basically runs right out to the edge of the T/B like on a normal Honda T/B, so I'm assuming that's the one for the MAP sensor... Any help would be greatly appreciated.
Old Dec 8, 2002 | 11:38 AM
Kataku2K3's Avatar
Default Re: Where to hook up MAP sensor for ITBs? (Clayton)
You don't have 4 ports.... as in one on each runner??? Normally all you gotta do is "T" or "Y" them all together and them bring them to one MAP sensor... I've seen it done other ways with all four lines running into a home made PVC pipe that has been capped off making a little cylinder, with 5 ports.... 4 for the vac... one for the MAP... You get it... Hope you understand... and if for some reason you on have 2 then just bring them together some way... Peace
Old Dec 8, 2002 | 05:54 PM
KS-R's Avatar
Default Re: Where to hook up MAP sensor for ITBs? (JDMspecEG6)
Wouldn't the variance in the vaccuum pressure cause an idle problem? Say for example on a normal manifold.. If you were to plug the line onto the manifold as oppose to the T/B.. wouldn't that cause the motor to idle differently? Not 100% sure.. just asking..
Old Dec 8, 2002 | 06:15 PM
Kataku2K3's Avatar
Default Re: Where to hook up MAP sensor for ITBs? (KS-R)
Well on my friend's race car it idles pretty good... Not really lumpy at all... They have the little PVC cylinder with the vacuum ports... It seems to work really well...
Old Dec 8, 2002 | 09:09 PM
KS-R's Avatar
Cool.. Sounds good enough.. PVC canister would be way easier and somewhat cheaper to make than an aluminium one too.. I'll keep that in mind.. Thanx
Old Dec 8, 2002 | 09:40 PM
Kataku2K3's Avatar
Yea, they had one that came with the manifold but they were tryin to keep it light and the canister that it came with was huge... Way bigger than it need to be ~(cylindric design 10" tall x 6" in diameter).. The PVC one is about twice as big as the MAP sensor itself.... Here's a pic of their car... It ran an 11.40 but that was with shitty gearing.. My friend Scott, the driver said that he hit it into 4th just as he crossed the 1320 mark... They reworked the tranny now so it should be good for atleast a 11.00... Hopefully high 10's..
Old Dec 8, 2002 | 09:42 PM
KS-R's Avatar
what motor is in there?
Old Dec 9, 2002 | 07:49 AM
Kataku2K3's Avatar
84mm Bore LSVTEC... high compression pistons, Portflow head, Toda C's, ITB's, RC 440's, custom side draft header... That's about it...
Old Dec 9, 2002 | 08:22 AM
qtiger's Avatar
You dont use the map sensor.
Old Dec 9, 2002 | 08:32 AM
KS-R's Avatar
Damn... I'm into the top of 4th by the 1320.. Stock JDM H22 LSD tranny.. I wonder if I can get some work done to that.. Hm....
Old Dec 9, 2002 | 09:38 AM
Kataku2K3's Avatar
Default Re: Where to hook up MAP sensor for ITBs? (qtiger)
Oh really.... That's funny I'll go take some pics of their motor if you want to see it... Yea they had the tranny set up with some long gears that got them some 1.5x 60fts. but the gears are just too long on top... My friend rebuilt it the other day so we'll see what it can do this coming season... Like I said should be able to pull a 11.00 hopefully high 10's... Latez
Old Nov 28, 2006 | 07:36 PM
repn a lude's Avatar
top of 4th your at a 100?? damn thats a plude trans?? my **** cuts out before the top of 4th at 120 lude
tony_2018
May 25, 2014 06:48 PM
pepetype
Feb 3, 2011 08:57 PM
didder
Dec 16, 2008 11:13 AM
AccordSleeperZzZ
Mar 6, 2007 07:33 PM
92hybridAccord
May 4, 2004 11:34 AM
