oil jet bolt thread stripped
Old Dec 5, 2002 | 07:54 PM
kanzenr91si's Avatar
Default oil jet bolt thread stripped
i was starting to put my b16 together when i found that my 1 and 4 cylinder oil jet bolt threads are stripped. i also found out they dont make heela coils that small either so im stuck. anyone had this happen to them? anyone have ideas? need help asap, im so close to vtec.
Old Dec 5, 2002 | 09:04 PM
kwil666's Avatar
Default Re: oil jet bolt thread stripped (kanzenr91si)
the same thing happened when i was putting my b18c1 back together. i stripped out the number 4 oil jet. we just plugged it and went on with life. im not sure about having two of them plugged. i was told if you bore a 1.8 b18c1 to a 2.0 then you cant use the jets anyhow and that engine will run good. or look at the ls-vtec they dont have them. although on the other had if you can find another block why not get it and start fresh.
Keith
Old Dec 5, 2002 | 11:30 PM
SuperSH's Avatar
Default Re: oil jet bolt thread stripped (kwil666)
Is there any way to drill and retap to the next larger size and find/make a new bolt for the jet?
Old Dec 6, 2002 | 12:31 PM
serious's Avatar
i'd drill and tap it to the next larger size and put a larger bolt in.
Old Dec 6, 2002 | 09:48 PM
Default Re: oil jet bolt thread stripped (serious)
then you have to make a perfect hole in that new bolt or else oil wont flow through it. me and a friend are going to try this at a machine shop. ill let you know how it goes.
Old Dec 6, 2002 | 11:25 PM
SuperSH's Avatar
A machine shop should be able to measure and drill a new bolt for oil flow at the correct flow rate.
guessinthe2000
Honda Motorcycles
Sep 15, 2007 09:16 AM
porter
Feb 16, 2007 11:39 PM
myuglycivic
Aug 1, 2005 06:05 PM
h46it
Apr 7, 2002 05:22 PM
