car DIED.
Old Dec 7, 2002 | 10:41 PM
EGsixer's Avatar
Default car DIED.
today as i was pullin out my driveway my car just shut off and died but the radio and everything else was workin fine...also i did not get any check engine lights either..anyone know what the problem could be? i went under the hood and moved **** around and after a while i could get it to start up again...then it would bog a little..but then not anymore..i dont know whats goin on...so i parked the car and came back to it..and tried to start it and it wouldnt start....and the battery and starters all good tho....any word on this? also..once i got it started..one of the times i revved it and it just revved and shot down to 0 rpms hella quick and shut off..
Old Dec 7, 2002 | 11:16 PM
B20Monster's Avatar
Default Re: car DIED. (EGsixer)
check and see if you have any fuel feeding into the motor.. a similar situation just happened to a friend of mine.. it turned out that her igniter in the distributor burned out..
Old Dec 8, 2002 | 12:14 AM
Greasemonkey75's Avatar
What model is your issue with?
[Modified by Greasemonkey75, 9:15 AM 12/8/2002]
Old Dec 8, 2002 | 10:51 AM
10K2HVN's Avatar
how many miles..?
Old Dec 8, 2002 | 01:38 PM
tnbigdawg's Avatar
Default Re: car DIED. (hondas suck)
sounds like an ignition problem to me
Old Dec 8, 2002 | 03:04 PM
EGsixer's Avatar
its a 2000 b16a2 motor ..with 20k miles on it..its fairly new...right now its runnin..but i dont know when it will do this again...i thought it wouldnt do it again but it did lastnight...
Old Dec 8, 2002 | 03:20 PM
ill phil's Avatar
What kind of car is the motor in- Si or Si motor swapped into 92-95? When it starts does it start up rev then drop and shut off and then won't turn on after that, then if you give a good 5-10 min. it will start up again?
Old Dec 8, 2002 | 03:28 PM
EGsixer's Avatar
Default Re: car DIED. (ill phil)
its in a 93 dx hatch....it did that too started then died out and wouldnt start for a little bit..but now it starts and stays runnin..and some times it starts and just dies and takes a little bit to get it started again...
Old Dec 8, 2002 | 03:34 PM
ill phil's Avatar
Mine had a similar problem. Sometimes it would start and run fine, other times it would start and die after a second or two and wouldn't start up again for a good 5 minutes or so then it was fine. Often this would happen after I turned the car off and came back to turn it on again..... the answer for me was a bad Main Relay. You can pull your main relay (under the dash by the hoop pop latch) and can test it for continuity across different circuits. If you have a Helms it will tell you how. Brand new the part is like $30 or something cheap and it completely fixed my random dying and starting problem. The main relay (fuel main relay) controls the power to the fuel pump which would cause the car to start up then lose fuel pressure and die. Good luck , hope something small like that is the problem, but I suggest testing your relay before just running out and buying a new one.
Old Dec 8, 2002 | 03:45 PM
EGsixer's Avatar
Old Dec 8, 2002 | 03:54 PM
b19coupe's Avatar
Sounds like the PGM-FI main relay to me too.
Old Dec 11, 2002 | 08:43 PM
It could be one of two things. Either the main relay is dieing, if this were the case the check engine lamp would not come on when cranking, after the car will not start or it died. The other problem could be the electrical portion of your ignition switch is going bad.
Old Dec 11, 2002 | 10:23 PM
ill phil's Avatar
Default Re: car DIED. (Greasemonkey75)
Actually even if the main relay is going bad or out, the check engine lamp still comes on after the car has died or when the ignition is turned on. Thats why it took me some time to narrow down the problem, nothing was acting different (besides my car obviously not starting and dying )
furiousbob
Jul 15, 2009 09:04 PM
Crono139
Mar 25, 2008 02:21 PM
Type Wah
Dec 6, 2004 03:18 PM
Malice
Jan 18, 2002 09:41 AM
