Rpm sputter between 7k-8krpm
Old Dec 8, 2002 | 06:37 PM
chirp3rd's Avatar
Default Rpm sputter between 7k-8krpm
ok i am have a problem after my car warms up when i hit 7000 rpms the tach needle starts to sputter.....it jumps from 7k to like 8k quickly and sometimes to like 8.5k but the cars seems to be still pulling. I am think its my sparks plugs are worn due to runnin rich what else can it be??? or is my tach just f@#ked up.
o yea its a jdm 2nd gen b16a
some 1 give me some ideas
Old Dec 8, 2002 | 09:13 PM
KS-R's Avatar
Default Re: Rpm sputter between 7k-8krpm (chirp3rd)
Sounds like it's your coil or the igniter pack... I've seen that numerous of times caused by either of those.. So.. that's what my guess would be.
Old Dec 9, 2002 | 05:02 AM
chirp3rd's Avatar
thanx ill check that out asap any1 else have any ideas
Old Dec 9, 2002 | 06:08 AM
b19coupe's Avatar
Default Re: Rpm sputter between 7k-8krpm (KS-R)
Yeah, definately sounds like something in the distributor, if not the coil or igniter, then the distributor itself.
Old Dec 9, 2002 | 03:45 PM
chirp3rd's Avatar
can this same problem cause the idle to be higher then usual
hondacivic90zc
12
Jul 3, 2009 08:57 AM
3rdGteg
Jun 5, 2006 02:36 PM
vinuneuro
Mar 20, 2005 10:42 PM
4door-r
Apr 23, 2004 04:01 PM
SIK IN DA HED
Nov 13, 2002 01:30 PM
