ecu pin #'s for EG 4 wire o2 conversion
Old Dec 7, 2002 | 06:13 PM
Cm91h22a's Avatar
Default ecu pin #'s for EG 4 wire o2 conversion
b16a going into 93 civic vx and need pin#'s for 4 wire o2 conversion...
Old Dec 7, 2002 | 06:47 PM
racerxadam's Avatar
Default Re: ecu pin #'s for EG 4 wire o2 conversion (Cm91h22a)
what ecu are you using?
Old Dec 7, 2002 | 07:22 PM
Cm91h22a's Avatar
Default Re: ecu pin #'s for EG 4 wire o2 conversion (racerxadam)
p28
Old Dec 7, 2002 | 08:17 PM
Jaker's Avatar
A6 for O2 sensor heater
D14 for O2 sensor signal
Old Dec 7, 2002 | 10:13 PM
racerxadam's Avatar
Default Re: ecu pin #'s for EG 4 wire o2 conversion (hndarcr)
A6 - o2 heater control
A25 - o2 heater ground
D14 - o2 signal
D22 - o2 signal ground
Old Dec 8, 2002 | 12:19 AM
Jaker's Avatar
Actually A25 is not a ground at all, it is a switched power. The way the O2 sensor heater circuit works, is the power comes from the chassis to the heater, and when the ECU deicdes to turn it on and off, it grounds out the circuit. It will work if you run the power from A25, but any of the black/yellow wires in the engine harness will work fine. As to the D22 O2 sensor signal ground, here's another place that you don't have to run back to the ECU, but can get a good ground at the thermostat housing.
Old Dec 8, 2002 | 01:48 AM
Kataku2K3's Avatar
Your VX isn't already wired for the 4 pin oxygen sensor or are you rewiring the motors loom??? Just wondering... Latez
Old Dec 8, 2002 | 08:17 AM
333's Avatar
333
Default Re: ecu pin #'s for EG 4 wire o2 conversion (JDMspecEG6)
I believe Hasport.com has an article in their tech section. They were sccm last year.
Old Dec 8, 2002 | 09:36 AM
Cm91h22a's Avatar
I'm just picking up where someone left off. I haven't seen the car, but they told me that this is all it lacks. I usually work on 88-91 civics&crx's so all the eg's are new to me and I just want to get it right the first time...thank for the info, very helpful.
Old Dec 14, 2002 | 09:23 PM
KStuned's Avatar
Default Re: ecu pin #'s for EG 4 wire o2 conversion (Jaker)
So you can just run the 2 black wires coming from the o2 to chassis grounds?
Old Dec 15, 2002 | 08:51 AM
Jaker's Avatar
Default Re: ecu pin #'s for EG 4 wire o2 conversion (Hondaddict)
No, one of the black wires goes to switched power, and the other goes to A6 on the ECU.
jDMJeRk
Oct 3, 2019 08:19 PM
houseofgrafix
Aug 16, 2010 08:49 AM
EF8IGHT
Nov 6, 2005 09:08 PM
gtpilot
Dec 12, 2002 12:27 PM
