half shafts stuck!!
Old Feb 29, 2004 | 04:24 PM
hatched92's Avatar
Default half shafts stuck!!
i broke my diff and i'm swapping the tranny but the half shaft is stuck and i can't get it out. any ideas? i've tried to pry it out but wont budge.
thanks
Old Feb 29, 2004 | 07:17 PM
Sobe_Death's Avatar
Default Re: half shafts stuck!! (hatched92)
its stuck in the tranny? pop off the lower balljoint so you can move the knuckle out of the way, pop off the axle retaining bolt on the hub, pull the axle out of the knuckle, then yank the sucker out of the tranny! if it doesnt want to move at first, yank it harder, it will come out
Old Feb 29, 2004 | 07:20 PM
boostn420's Avatar
get a long punch\drift and put it through the other axle hole and hammer away.
Old Feb 29, 2004 | 07:38 PM
Sliced Beard's Avatar
Default Re: half shafts stuck!! (boostn420)
this may be a stupid question
but have you loostened up all THREE blots that attach it to the block
it should just pop right out. i have never had any problems withe getting one out, but getting one int is a different story. sometomes the little c-clip likes to be stubborn.
Old Feb 29, 2004 | 10:54 PM
T.J.'s Avatar
Default Re: half shafts stuck!! (dirtyd463)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyd463 &raquo;</TD></TR><TR><TD CLASS="quote">this may be a stupid question
it should just pop right out. i have never had any problems withe getting one out, but getting one int is a different story. sometomes the little c-clip likes to be stubborn.</TD></TR></TABLE>
yeah have you removed the 3 bolts that attach it to the block. If you haven't thats the problem. The half shaft is usually the easiest to of the two axles and its self to get out. And for me it goes in just as easy as it comes out. If it does kinda give you a little trouble just use a screwdriver as leverage to push it out of the transmission.
Old Mar 1, 2004 | 08:53 AM
hatched92's Avatar
guys i understand completely for you asking if i took out the three bolts and if course i have. i do trannys often for friends ect but i've never had one get stuck like this. they always just pop right out with a little tap if needed. i just dont understand. is it possible that it could be bent from when the diff broke? i mean the least amount would not let it out.
Old Mar 1, 2004 | 08:59 AM
mattssi's Avatar
Default Re: (hatched92)
When i was taking mine apart from my diff blowing up, It slid right out, almost too easy. I can imagine it being beny or anything. Try getting some wd 40 in there, possibly from the other side, and then give it a pull.
Old Mar 1, 2004 | 10:26 AM
hatched92's Avatar
well good news. i got it out, i had to use a sludge hammer and have it against the driveway and a rod and hit it as hard as i could about 10 times and it finally popped out.
Old Mar 1, 2004 | 11:22 AM
T.J.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatched92 &raquo;</TD></TR><TR><TD CLASS="quote">well good news. i got it out, i had to use a sludge hammer and have it against the driveway and a rod and hit it as hard as i could about 10 times and it finally popped out. </TD></TR></TABLE>
Dam man ive never had one stick that bad
NoVALude
Apr 28, 2006 07:54 AM
ABK
13
Dec 28, 2004 05:24 PM
civickiller
Mar 15, 2004 01:38 PM
jaxle
17
Oct 28, 2003 07:26 AM
Digitalcivic
Dec 22, 2002 09:11 PM
