Bleeding brake fluid?
Old Feb 29, 2004 | 01:14 PM
udm_motorsport's Avatar
Default Bleeding brake fluid?
Hi everyone,
I just installed some new brake pads. Now i need to bleed the brakes...but i've never done this on my car nor for a car with rear drum brakes.
I have a 90 civic si.
Do i have to bleed all 4 corners or just the fronts?
thanks
franklin
Old Feb 29, 2004 | 01:47 PM
99b18's Avatar
Default Re: Bleeding brake fluid? (to_carpediem)
if u just replaced pads. u should not need to bleed the brakes. as long as u did it properly. u only need to bleed the brakes if u had the system open. to change pads. all u should do is compress the piston back in to the bore on the caliper. then change the pads. and re attach the caliper. there is no need to take the brake line off of the caliper.
Old Feb 29, 2004 | 03:58 PM
Default Re: Bleeding brake fluid? (99b18)
actually, i dont need to bleed the system but i really want to as the last time i did it was about a year ago and i want to have fresh fluid in the system before i start autocrossing.
thanks
franklin
Old Feb 29, 2004 | 05:29 PM
Adam F's Avatar
Here I did a google search for you. First response. http://www.angelfire.com/nj3/t....html
namewasdallas
Suspension & Brakes
Apr 6, 2010 08:06 PM
Smash03
Suspension & Brakes
Mar 24, 2006 12:26 PM
baked_beanz
Jun 2, 2005 09:33 AM
civic_976
Mar 6, 2003 04:10 AM
civic_976
Mar 5, 2003 09:11 PM
