Frustrated and need help!! No Start.
Old Mar 1, 2004 | 08:25 AM
pnugs's Avatar
Default Frustrated and need help!! No Start.
My 95 civic DX shut-off while driving and will not start but does turn over. I went through all the procedures of checking for spark (none )and fuel (yes), etc. I even replaced the icm (actually the whole distributor), ecu and checked the main relay checked all fuses and looked for damaged wires and still no start. Now, I checked my timing belt its okay its actually only 2 weeks old but I did notice the top gear bolt was loose so I tightnened it down and tried to start it again but again nothing and noticed the bolt was loose again...mmm. Please help!.
Old Mar 1, 2004 | 11:47 AM
Redline130's Avatar
Default Re: Frustrated and need help!! No Start. (pnugs)
If the cam gear bolt was loose, there is a possibility that your timing is messed up now. Hopefully there isn't any internal damage done to your motor. I would check to see that the cam is in time with the crank, hopefully it still is. Also, check to see if your valvetrain is still OK.
spyder98
May 13, 2011 06:59 AM
eg2GAMEOVER
Feb 22, 2009 03:41 PM
RenzoDaPlayboi
Nov 3, 2006 10:01 PM
metalgears
Aug 23, 2004 12:01 PM
pbizzlegsr
Jul 7, 2004 10:23 PM
