lsvtec main / oil seals
Old Feb 27, 2004 | 05:43 AM
lsvtec101's Avatar
Default lsvtec main / oil seals
im using the itr oil pump will i need a itr oil seal or ls? and the main seal should be itr or ls? Thanks!
Old Feb 27, 2004 | 05:46 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: lsvtec main / oil seals (aemcivic_02917)
since you're using the itr pump, get an itr oil seal. as for the rear main seal, it should be coming from your factory ls block correct?then get one for the ls. but you never know, they may be the same part #.
Old Feb 27, 2004 | 05:50 AM
lsvtec101's Avatar
Default Re: lsvtec main / oil seals (vtecb20coupe)
**** i was just looking at my itr oil pump , do they come with the oil seal? i think it has been in it already.
Old Feb 27, 2004 | 08:29 AM
mmuller's Avatar
Mad Scientist
theyt are all the same
Old Feb 27, 2004 | 01:50 PM
boostn420's Avatar
yes they come with the oil seal but not the o-ring on the back so get a new one of those.
Old Feb 27, 2004 | 05:40 PM
lsvtec101's Avatar
Default Re: lsvtec main / oil seals (boostn420)
what o ring?
Old Feb 27, 2004 | 06:10 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aemcivic_02917 &raquo;</TD></TR><TR><TD CLASS="quote">what o ring?
the o-ring is on the oil pump
MasterLsGod
Oct 24, 2009 05:02 PM
Turbo_TONY
Jul 26, 2006 11:32 AM
Ls_V_TurboSi
May 10, 2006 05:14 AM
pinota
Jul 16, 2002 06:47 AM
