No spark/fuel no start
Old Mar 1, 2004 | 05:31 AM
advanracing62's Avatar
Default No spark/fuel no start
I've searched and seen that the most common things are Main relay or bad ECM. Is there anything else that may cause this? I know my wiring is spot on, so that's not even an issue. I've checked the ECM and I don't think that is the issue either, and the Main seems to be funcional- when put into another car. Anyone have any thoughts?
car- 98 LS with GSR harness, OBDI motor, no SRS installed
could taking out the srs cause the issue? I noticed that the srs and fuel pump were on the same fuse.
Old Mar 1, 2004 | 06:47 AM
doublejz's Avatar
Default Re: No spark/fuel no start (advanracing62)
Pulling the srs shouldn't involve it. i didn't think the the srs and fuel are on the same fuse. I thought the srs fuse had a yellow rubber on it and the fuel was right beside it. (might be wrong) My guess would be the main relay though.
Old Mar 1, 2004 | 07:04 AM
Default Re: No spark/fuel no start (doublejz)
I'm going to get a new Main, just found out that one of my moron friend's doesn't know how to hook up a battery charger and put the neg on pos. to charge... which could have blown the main
Old Mar 1, 2004 | 07:32 AM
is the OBDI main the same as the OBDII?
Old Mar 1, 2004 | 11:04 AM
Main relay has been elminated- anything else?
Old Mar 1, 2004 | 11:54 AM
other thoughts here?
Old Mar 1, 2004 | 01:22 PM
EKhatch's Avatar
Did you find out what those other plugs were for? Do they both have to have relays on them?
Old Mar 1, 2004 | 02:02 PM
Default Re: No spark/fuel no start (EKhatch)
I don't know... I can always take a relay out of the vic, but I bought a new main relay today... I'm going to get another ECM and see if that is the issue... I hope she starts tonight, I can't take much more of this ****!
Old Mar 1, 2004 | 06:09 PM
ECM and Main relay are totally eliminated as issue- anyone have any ideas?
Old Mar 1, 2004 | 06:27 PM
boostn420's Avatar
what ecu do you use?
Old Mar 2, 2004 | 05:26 AM
Default Re: No spark/fuel no start (boostn420)
P72
Old Mar 2, 2004 | 06:19 AM
would the motor being OBD I and not OBII have any effect?
Jcgbeasttube
Honda Civic (2006 - 2015)
Mar 19, 2018 10:07 PM
shwanC
15
Dec 4, 2013 12:31 PM
mihaelrosas
Jun 8, 2007 04:27 PM
EJ1_203
Sep 10, 2006 04:36 PM
bo0sted
Mar 9, 2004 05:05 PM
