Timing belt deflection (video)
Old Feb 29, 2004 | 09:29 PM
petrv's Avatar
Default Timing belt deflection (video)
I probably figured out my problem with noise going form timing belt area after the timing belt change. I was not alone with this problem, more people have these problems.
I knew (and many people told this to me) that when I loose my timing belt, the noise stops, but I was worried about vibrations that the belt made when the engine was running. Today, I made some videos with my and my friend's lude to ask you about it.
Here are the vids:
Original state, with the tensioner set according to the Helms, the noise is still present:
engine running - no vibrations
belt slack with piston #1 at TDC - looks pretty tight
Loosened belt, so the noise has gone:
engine running - the noise has gone, but notice the vibrations at some engine speed. Is this ok?
belt slack with piston #1 at TDC - looks unchanged
maximum belt slack - I tried to rotate the crank and find the position with maximum slack - here it is. Looks loose.
I was really confused, so I called my friend with the same lude (H22 4G), but still with the auto tensioner, so the results should be the right ones.
engine running - the vibrations look exactly the same as mine
belt slack with piston #1 at TDC - looks same as mine.
maximum belt slack - again same as mine.
So, I hope the vibrations are OK, what do you think? Can I drive with this belt slack and vibrations? Or is this slack not normal?
Old Mar 1, 2004 | 06:06 AM
petrv's Avatar
Default Re: Timing belt deflection (petrv)
I would like to add that there are no vibrations on other timing belt sections- only between exhaust camshaft and the crankshaft.
Old Mar 1, 2004 | 06:20 AM
mmuller's Avatar
Mad Scientist
It should be ok, but you could ''maybe'' try to tighten it a little more so is right in balance with no noise or vibration. Drove my car with that same vibration or worse for the longest time and had no problems.
Old Mar 1, 2004 | 09:49 AM
petrv's Avatar
Default Re: Timing belt deflection (mmuller)
OK, I will try to tighten it a bit.
Old Mar 1, 2004 | 09:56 AM
dip-set's Avatar
doesnt the timing belt need a lil time to break in...hence its a lil tight causing that humming sound till it wears/breaks in a lil bit more...?
nicknack25
Apr 10, 2012 11:00 AM
Psycho719
Sep 14, 2011 04:28 AM
ekx4
Aug 28, 2006 12:18 AM
bam181
Aug 20, 2006 05:16 AM
petrv
Mar 1, 2004 10:32 AM
