B18C bore?
Old Mar 2, 2004 | 07:18 AM
rocket256's Avatar
Default B18C bore?
Ok; I have a B18C. I know that the bore is 81mm and the stroke is 87.2mm. The motor is getting bored over to 83mm. What will it be? A 1.8L or a 1.9L? After doing the math I came up with 1887.420 for displacement. Is this correct?
If so how in the world people clame that they have a 2.0 when it is a B18C with 84mm x 87.2mm =1933.171 displacement. The stoke never changed. And even if it was 89mm it would only be 1973.071. Now that I could see.
But anyway; what would I be a 1.8L or 1.9L?
Old Mar 2, 2004 | 07:58 AM
mmuller's Avatar
Mad Scientist
Default Re: B18C bore? (rocket256)
it would be a 1.9 liter
Are you boring t 83mm on stock sleeves?
Old Mar 2, 2004 | 09:47 AM
rocket256's Avatar
Default Re: B18C bore? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">it would be a 1.9 liter
Are you boring t 83mm on stock sleeves?</TD></TR></TABLE>
No; It getting good ol Gorillia sleeves!!!
Old Mar 2, 2004 | 02:17 PM
AzG35's Avatar
I believe they aren't true 2.0 liters with 84mm GSR blocks. I think they are closer to 1.93 liters.
Old Mar 2, 2004 | 08:51 PM
jeremy.'s Avatar
Default Re: B18C bore? (AzSi22)
yes that's true....a true 2 liter i believe is 86mm bore...unless you are using a larger crank
Piv
Aug 27, 2010 09:42 PM
Del Sol on Steroids
Dec 14, 2006 05:25 PM
gulftiresinc
10
Aug 17, 2004 05:57 PM
tooqwik1
Feb 18, 2003 11:51 AM
