clutch set-up?
Old Feb 26, 2004 | 12:58 PM
DualCamDan's Avatar
Default clutch set-up?
if my clutch disk breaks will that hurt my pressure plate? can i just buy a new clutch disk or do i have to buy a whole new kit?
Old Feb 26, 2004 | 06:47 PM
ultimatehonda's Avatar
Default Re: clutch set-up? (whitey_4g)
You should buy a new clutch kit (disk, PP, throwout bearing, and piolt bearing) Once something breaks you want to make sure you change everything, as everything wears together.
Old Feb 26, 2004 | 06:55 PM
Kataku2K3's Avatar
Default Re: clutch set-up? (ultimatehonda)
With most any brand you should be able to buy just a disk... I also wouldn't recommend just buying a disk if you planning on running your current clutch till it goes (that's also wearing on the pressure plate, etc.)... It is possible to damage your pressure plate but like I said it depends on how long you're planning on going... When it comes time to change your clutch, pull the pressure plate and inspect it... While everything is off (unless you've changed recently) I would swap the throwout/pilot bearings, and resurface the flywheel... As ultimatehonda said, you really should just buy a new kit... Just my $0.02
Old Feb 26, 2004 | 09:16 PM
DualCamDan's Avatar
i put a centerforce in about a 8 months ago, but i thought about getting a 6 puck disk for it and using my centerforce pressure plate. i am going to get a lightened flywheel when i go my clutch and a new t.o.b. too so or as far as doing a new disk?
blue_hatch
Sep 1, 2008 06:30 PM
miguel6632
Nov 29, 2006 08:37 AM
Honda Sport
Apr 25, 2006 03:27 PM
93FastLs
Sep 1, 2005 07:28 PM
Riake
Aug 16, 2004 12:31 PM
