Dropping idle after reving
Old Feb 28, 2004 | 03:49 PM
roydogg's Avatar
Default Dropping idle after reving
My idle drops to about 200 then back to 750 only when I rev it either in gear or in neutral. It would drop but catch and has cut off on me once or twice when I pick on it. My setup consist of
b18b
18g turbo w/hondata s200
440cc w a 255lph intank
ngk7's
Tuned to a perfect 12.1 A/F ratio, just can't seem to fix this dropping idle.
Old Feb 28, 2004 | 05:47 PM
NitrousB.I.G.'s Avatar
Default Re: Dropping idle after reving (roydogg)
It could be that you are too rich on the bottom end. If thats not it I think there is an ajustment on the tb that controls how the engine comes back to idle(I think you have to remove the tb to get at it). I have not done this before so I cant help much more. There should be something about this in your factory manuel if you dont have one then there might be someone here that can help.
Old Feb 29, 2004 | 11:38 AM
roydogg's Avatar
Default Re: Dropping idle after reving (NitrousB.I.G.)
I might be runnin rich but the idle holds steady and nice. It's only when I rev it even a little bit the idle would drop. Any more thoughts?anyone?
ciiivic89
Feb 9, 2009 07:03 PM
deklao
Jan 23, 2008 12:14 PM
turbotime
Oct 24, 2005 12:01 PM
slimbo
May 16, 2004 10:57 PM
b16a1civichb
Aug 8, 2003 11:48 AM
