Timing Help Please!
Old Jan 21, 2006 | 12:26 PM
D21X's Avatar
Default Timing Help Please!
Here's the pics of the cam gears and the crank pulley. I just need confirmation that the timing belt is off. To get it correct, all I need to do is move the crank so that it is aligned with the crank/cover marking correct? Please confirm that what I am doing is accurate and correct. Thanks!
Old Jan 21, 2006 | 12:29 PM
D21X's Avatar
Default Re: Timing Help Please! (D21X)
Or, to line up the timing belt do I need to remove the cranklpulley and actually line it up with the marks on the engine block???
Old Jan 21, 2006 | 08:34 PM
mrlegoman's Avatar
Make sure your cams are TDC first. Their not in your pic.
Old Jan 22, 2006 | 01:36 AM
projectTeG's Avatar
Default Re: Timing Help Please! (mrlegoman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrlegoman &raquo;</TD></TR><TR><TD CLASS="quote">Make sure your cams are TDC first. Their not in your pic.</TD></TR></TABLE>
from the looks of it id say you crank is off a few degrees and your exhaust cam is off about a tooth.
just spin the crank to tdc...then remove the belt from the cam gear and line them up and put it back on and re-tighten it to spec.
Old Jan 22, 2006 | 02:35 PM
dabig1(2)'s Avatar
Default Re: Timing Help Please! (projectTeG)
the timing marks on our accords are on the flywheel, not the crankpullies.
Old Jan 22, 2006 | 03:34 PM
Runnerdown's Avatar
Default Re: Timing Help Please! (dabig1(2))
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dabig1(2) &raquo;</TD></TR><TR><TD CLASS="quote">the timing marks on our accords are on the flywheel, not the crankpullies.</TD></TR></TABLE>
Thats not an accord engine though
Old Jan 23, 2006 | 12:39 AM
projectTeG's Avatar
the a b-series vtec engine there buddy...lol
Old Jan 23, 2006 | 05:44 AM
dabig1(2)'s Avatar
lol, hey yesterday when i saw this thread the second picture with the dohc head was either not there or didnt load for me.
goota
Aug 22, 2009 07:38 AM
D21X
10
Jan 21, 2006 06:57 PM
JediKGB
Dec 4, 2005 02:29 PM
94dxt
Oct 27, 2004 12:36 PM
