B16 Oil pressure problems.
Old Jan 24, 2006 | 04:23 AM
H22AJSPEC's Avatar
Default B16 Oil pressure problems.
I cant find any trouble shooting in the helms for this so I assume its the oil pump . my b16 as it warms up starts to drop oil pressure and once it is at full operation temp it drops 2 zero at idel . Oil pump? or what else could it be ? I did search found know real answers. Thanx for any help or suggestions you may have!
Old Jan 24, 2006 | 05:10 AM
H22AJSPEC's Avatar
Default Re: B16 Oil pressure problems. (H22AJSPEC)
ttt
Old Jan 24, 2006 | 03:03 PM
H22AJSPEC's Avatar
anyone?
Old Jan 24, 2006 | 06:55 PM
rintegration's Avatar
What kind of oil pressure gauge are you using?
Old Jan 24, 2006 | 07:16 PM
H22AJSPEC's Avatar
Default Re: B16 Oil pressure problems. (rintegration)
autometer mechanical at startup its 25 or so and then works its way down to zero once warmed up
Old Jan 25, 2006 | 05:58 AM
mmuller's Avatar
Mad Scientist
have you strated by the obvious stuff like changing the oil and filter?
could be your pump release pressure spring
Old Jan 25, 2006 | 04:42 PM
H22AJSPEC's Avatar
Default Re: B16 Oil pressure problems. (mmuller)
even so I would need to repace pump right? are there any other tests to run ?
superspadez
Aug 31, 2012 01:38 PM
93turbo16
Jan 30, 2006 06:03 PM
gaskleppie
Sep 27, 2003 06:45 AM
