Balljoint press
Old Jan 23, 2006 | 08:14 AM
Batoutahell's Avatar
Default Balljoint press
I'm trying to press out my front lower balljoint, as the threads are mangled. My local Autozone (and other parts stores) has the "free rental" kit, but it doesn't have the correct shims that fit my balljoint ('00 integra).
Has anyone used this http://www.harborfreight.com/c...=3552 or this http://www.harborfreight.com/c...=3551? If they would work on balljoints, it might be nice to have a desktop press around the garage.
Old Jan 23, 2006 | 12:06 PM
dognutz's Avatar
Default Re: Balljoint press (Batoutahell)
I'm not sure what you need shims for. I used a tool that had 2 arms and a large bolt in the middle. The arms hold onto the knuckle and the bolt presses the balljoint out. I placed a thick piece of metal on top and beat the new one in to place. Do not hit the balljoint directly on either side as this can cause damage and problems when removing and installing. Althouth I would like a press also, you would have to remove the part to put into the press. I guess it depends on how often you might use one.
Old Jan 23, 2006 | 01:25 PM
Tyson's Avatar
the autozone rental balljoint press will work fine.
EXCEPT, when you press the new one in, be sure to not completely collapse the balljoint in the press. the sleeve is not deep enough to fully press the balljoint in, and can bottom out the threads on the balljoint. so be carefull.
Old Jan 23, 2006 | 02:13 PM
B18EG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Batoutahell &raquo;</TD></TR><TR><TD CLASS="quote">Has anyone used this http://www.harborfreight.com/c...=3552 or this http://www.harborfreight.com/c...=3551? If they would work on balljoints, it might be nice to have a desktop press around the garage.</TD></TR></TABLE>
I guess I am a little confused, but how will the pressing piece fit into the knuckle to press on the flat side of the balljoint?
Old Jan 23, 2006 | 02:16 PM
Tyson's Avatar
Default Re: Balljoint press (B18EG6)
um yeah, them arbor presses arent going to be good for anytihng but lower control arm bushings, if at all. definately not what you need.
Old Jan 23, 2006 | 02:20 PM
Default Re: Balljoint press (Tyson)
I picked this up instead, on sale today. http://www.harborfreight.com/c...38335 We'll see if it does the trick.
Old Jan 23, 2006 | 02:28 PM
Tyson's Avatar
exact same thing you get from autozone.
take note of what i said above.
Old Jan 24, 2006 | 07:12 AM
B18EG6's Avatar
ahhhh I see it now. How much does it cost to rent from autozone?
Old Jan 24, 2006 | 08:14 AM
hayabusa160's Avatar
4 pound hammer works good too.
Old Jan 24, 2006 | 09:20 AM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18EG6 &raquo;</TD></TR><TR><TD CLASS="quote">ahhhh I see it now. How much does it cost to rent from autozone?</TD></TR></TABLE>
free.
Old Jan 24, 2006 | 10:08 AM
snatch's Avatar
Default Re: Balljoint press (hayabusa160)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hayabusa160 &raquo;</TD></TR><TR><TD CLASS="quote">4 pound hammer works good too. </TD></TR></TABLE>
What I used
Old Jan 24, 2006 | 11:35 AM
shutta's Avatar
i think autozone charges a deposit but you get it all back when you bring the tool back
albertdiaz3
Suspension & Brakes
11
Nov 26, 2014 04:42 PM
Steppin Razor
Suspension & Brakes
Apr 3, 2007 02:30 PM
00IntegrAllmotoR
Aug 30, 2005 04:34 PM
speed_racer012
32
Mar 12, 2004 02:58 PM
g2man
Nov 29, 2003 02:30 AM
