I need an answer ASAP please
Old Jan 23, 2006 | 08:52 AM
BoogiepopJDM's Avatar
Default I need an answer ASAP please
Im going to be receiving a d15b7 motor today, freebie, infact the only thing i need is the head the only problem is the #1 cylinder compression is 25. i was wondering if that was more of a block issue or does the head actualyl have anything to do with it. I can either
A. if the head might be the problem remove the whole valve train and clean the head. and reassemble it.
or
B. its not the head. the problem is the block and i can go ahead and slap the head on my motor with a new gasket.
thanks guys
im picking up the motor tonight
Old Jan 23, 2006 | 09:01 AM
bdavis's Avatar
Default Re: I need an answer ASAP please (BoogiepopJDM)
either valve is fucked up in that cylinder or the piston rings are gone in the bottom end. was it turboed or anything? why is it free? how many miles?
Old Jan 23, 2006 | 09:02 AM
92 4doorsleeper's Avatar
it could be either one.
Modified by 92 4doorsleeper at 3:22 PM 1/23/2006
Old Jan 23, 2006 | 09:41 AM
never boosted as far as i know, free because of that compression problem. they just swapped another d15 in their car i just need the head to have 16 valve i only have 8 right now
Old Jan 23, 2006 | 10:38 AM
tgreaves's Avatar
Default Re: (BoogiepopJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoogiepopJDM &raquo;</TD></TR><TR><TD CLASS="quote">never boosted as far as i know, free because of that compression problem. they just swapped another d15 in their car i just need the head to have 16 valve i only have 8 right now</TD></TR></TABLE>
Could be either.. If the head is still on it, i would put some oil in the cylinders and try a compression test again and see if it changes..
kyky
Honda Civic (2006 - 2015)
Jul 29, 2017 01:36 PM
310BHPB16
Aug 26, 2005 07:59 PM
Flydad10
Oct 18, 2002 02:43 PM
kamira
Jun 30, 2002 01:17 PM
