stupid trans question
Old Jan 17, 2006 | 05:21 PM
ewaugh's Avatar
Default stupid trans question
Okay, I have the trans out of the car...now how do I get the thing apart?
Old Jan 17, 2006 | 09:07 PM
adim's Avatar
Default Re: stupid trans question (ewaugh)
It depends on the model, what do you have?
Old Jan 17, 2006 | 09:38 PM
ewaugh's Avatar
Default Re: stupid trans question (adim)
'91 Civic Si, cable trans...YS1 I think? That's what comes to mind but it could be wrong
Old Jan 18, 2006 | 05:36 AM
adim's Avatar
There are 3 bolts you have to remove in addition to the 20 bolts that hold the cases together. One is for the reverse gear shaft and 2 hold the detent ***** on the shift forks. Then you should be able to pull the halves apart. It may take some GENTLE prying if it's the first time the trans has been opened.
Old Jan 18, 2006 | 05:38 AM
Rukusmasta2's Avatar
buy a helms or search on here...or go to redpepperracing.com and click service manuals...that may help u out depends what car u got
Old Jan 19, 2006 | 02:06 PM
ewaugh's Avatar
Default Re: stupid trans question (Rukusmasta2)
Am I correct in thinking that the little snap ring at the end of the transmission opposite the bell housing has to come off for the sides to seperate? Any tricks on getting that damn thing loose?
Old Jan 20, 2006 | 05:04 PM
h22 civic's Avatar
snap ring pliers getting it apart is easy putting it back on is a mf
Old Jan 21, 2006 | 03:01 PM
adim's Avatar
Default Re: stupid trans question (h22 civic)
Yes, you need a snap ring pliers and I believe when you expand it the shaft will drop so that you can remove the case half. When reassembling, push the case down while expanding the ring, when the case half is seated and you re-install all the bolts holding them together just turn it over and you will hear the shaft drop and the snap ring re-seat itself.
EFS463
Jun 23, 2012 09:18 PM
93NTEGLS
Nov 29, 2007 04:34 AM
92hatchboi
Oct 9, 2007 05:53 PM
sycamore
Nov 13, 2005 04:28 PM
giooooo
Jul 20, 2002 10:29 AM
