What sensor is this?
Old Jan 24, 2006 | 07:41 PM
lazykiwi's Avatar
Default What sensor is this?
Can anyone tell what sensor is this? when i took it out one time, antifreeze came out. i've got a 98 gsr swap in my crx. it has aluminum foil around it since it's broken. i want to fix it, but i'm not sure what it is...
here is a pic. You can see where it is relative to the distributor:
here is a closer shot:
Old Jan 24, 2006 | 07:45 PM
gsrious's Avatar
coolant temp switch?
Old Jan 24, 2006 | 07:59 PM
1990DA's Avatar
Default Re: What sensor is this? (lazykiwi)
Coolant temperature sensor.
Old Jan 25, 2006 | 05:40 AM
RedSiHatch's Avatar
coolant temperature sensor
Old Jan 25, 2006 | 05:47 AM
mmuller's Avatar
Mad Scientist
Default Re: What sensor is this? (RedSiHatch)
thats the fan switch
Old Jan 25, 2006 | 06:03 AM
RedSiHatch's Avatar
which is the coolant temperature sensor, it tells the ecu when to turn the fans on cuz the motor is too hot.
Old Jan 25, 2006 | 09:09 AM
JimBlake's Avatar
The ECU has its own temperature sensor. The ECU has nothing to do with the fan circuit at all.
Old Jan 25, 2006 | 03:10 PM
HondaCivicSiR1's Avatar
Default Re: What sensor is this? (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">thats the fan switch</TD></TR></TABLE>yes it is
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedSiHatch &raquo;</TD></TR><TR><TD CLASS="quote">which is the coolant temperature sensor, it tells the ecu when to turn the fans on cuz the motor is too hot.</TD></TR></TABLE>it is on the dizzy side of the head
Old Jan 25, 2006 | 07:05 PM
philafelman's Avatar
Default Re: What sensor is this? (HondaCivicSiR1)
how is it broken, is the thermostat housing cracked, or is the sensor bad....why is it covered in foil. if the sensor is bad, replace it-it controls the fan, which you will want to work if you dont want it to overheat (should be under 60 bux from dealer).
Old Jan 26, 2006 | 10:02 AM
tgreaves's Avatar
Default Re: What sensor is this? (philafelman)
Its the fan switch.. I think Honda calls it a Thermoswitch..
jtrig
May 31, 2011 06:25 PM
ONEFASTJDM
Jul 16, 2009 10:37 PM
Simmerman
12
Sep 18, 2007 07:05 PM
Jeff1119
May 24, 2004 11:39 AM
