engine builder in maryland
Old Jan 19, 2006 | 04:57 PM
sc4dr's Avatar
Default engine builder in maryland
Does anyone suggest a good engine builder in maryland that can look at my motor. Its been built, and sleeved recently, and I damaged something today, its knocking on the bottom end(timing belt jumped a tooth, and overheated). My previous engine builder hurt his back. BTW its a stroked B18C1 any help appreciated
Old Jan 19, 2006 | 06:53 PM
voiceinurhead05's Avatar
Default Re: engine builder in maryland (sc4dr)
I don't know anything about engine builders in your area, but I can give you some ideas of what's wrong.
One of your connecting rods may have loosened itself which would cause the piston to knock and the crank rotation to be interrupted, which could offset your timing. The only way to find out is to tear apart the block and look for a broken rod.
Another problem could be poor lurication. Drain you oil and check it for metal shavings. It's possible that the cylinder that developed the knock seized momentarily due to a lack of oil. This piston seizure would also cause the timing to jump a tooth or two.
Old Jan 20, 2006 | 04:47 PM
h22 civic's Avatar
Default Re: engine builder in maryland (voiceinurhead05)
contact doublej on here check my sig justiceraceengines
Old Jan 21, 2006 | 03:28 AM
Gtracer15's Avatar
Best is in your neighbour hood. http://www.jeimportperformance.com out of Baltimore. Full service shop, dyno, builds etc and very experienced in swaps. Ask for James.
S2K Tom
Jun 1, 2015 04:36 AM
downtime1
May 24, 2010 06:16 PM
stewdabaker
Feb 24, 2006 03:15 PM
Blue CRX
Oct 27, 2004 04:28 PM
crashtest Sonny
Aug 9, 2003 02:53 PM
