blown engine - b18 bottom on zc head
Old Jan 22, 2006 | 08:16 PM
elecgenius's Avatar
Default blown engine - b18 bottom on zc head
is it possible? i dont know what engine i can throw my zc head onto. my bottom was built with perf pistons and the top with cams. i blew a piston trhough the side (long story). would i b able to set my head from my dohc zc onto the b18 bottom or a d16?
Old Jan 22, 2006 | 11:45 PM
92 4doorsleeper's Avatar
Default Re: blown engine - b18 bottom on zc head (elecgenius)
no.. ZC head fit ZC & D16A1 bottom... thats about it.
Old Jan 23, 2006 | 06:42 AM
jdm_slo's Avatar
no will not even get close to fitting
Old Jan 23, 2006 | 06:54 AM
elecgenius's Avatar
Default Re: blown engine - b18 bottom on zc head (jdm_slo)
thanks. what about an old 88 ls, will that fit, and also, you mentioned the d16,,,why not the d15?? thanks once again
Old Jan 23, 2006 | 07:55 AM
v4lu3s's Avatar
RTFM
the d16a1 is the 86-89 integra engine.
Old Jan 23, 2006 | 02:24 PM
88 ls IS d16a1... Which is the less power making USDM version of the ZC. D16A1 is a DOHC d-series like the ZC, their the only ones able to interchange top end parts. But You also cant use a D16A1 bottom in your car because the tranny bolts differently to the block
Old Jan 25, 2006 | 04:48 PM
elecgenius's Avatar
thanks fdor everyoes help. i did the impossible. i swapped a d16a to my ride cus i was desperate to get it running. the tranny had a lot of mods done to it (including retapping). engine mount was the hardest cus i got a block with power steering and had a different type of mount. i also swapped the pistons on to the d16z and polished, ported my head. it runs great. thanks once again for the help
tyler100
Oct 22, 2008 01:59 PM
vtec killin
Jun 15, 2007 10:41 AM
wushubrian
Jun 22, 2006 11:56 PM
wicked2night
10
Sep 25, 2003 02:52 PM
$criptah
Aug 10, 2001 09:03 AM
