What does a missfire feel like?
Old Jan 17, 2006 | 03:41 PM
idewson's Avatar
Default What does a missfire feel like?
Is it somewhat subtle? When the engine is idling it runs smooth then i get a slightly harder vibration...smooth, then slightly harder vibration...etc. Is this a missfire?
Old Jan 17, 2006 | 04:03 PM
ugrusa's Avatar
Default Re: What does a missfire feel like? (idewson)
a miss fire is when the car is missing a spark(s). check your sperk plugs and wires
a missfire will make the car hesitate and not idle corectly at a stop. good luck man!
Old Jan 17, 2006 | 05:27 PM
alpine_hikr's Avatar
that kind of sounds like a vacuum leak to me. So when you watch the tach does it dip down then catch its self?
Old Jan 18, 2006 | 10:41 AM
idewson's Avatar
Default Re: What does a missfire feel like? (alpine_hikr)
the rpms fluctuate with up to 200 rpms difference (ex. from 1k dropping to 800 then going back to 1k. could that also be from pressure leaking due to a bad gasket?
Old Jan 18, 2006 | 11:40 AM
boostinaintez's Avatar
you will definitely notice it sputters backfires black smoke out of tailpipe in extreme cases etc. doesn't sound like a misfire to me
Default Re: What does a missfire feel like? (boostinaintez)
ya could be a head gasket do a leak down test if you can get a hold of one or even compression check most likely a small vacuum leak put a vacuum gauge on it and post your results
EM2 Charlay
Honda Civic (2001 - 2005)
Sep 3, 2013 05:32 PM
Mr.DXt
Jan 13, 2010 08:27 AM
extrmeboost
Mar 18, 2003 09:36 PM
avex
Mar 18, 2003 05:44 PM
GruvyTune
Jul 30, 2001 12:44 PM
