Messed up Eagle rod threads question..
Old Jan 24, 2006 | 07:08 AM
tgreaves's Avatar
Default Messed up Eagle rod threads question..
I messed up one of the threads on one of my eagle rods.. It uses the ARP2000 bolts.. What is the thread and pitch size of the thread(not the bolt) so that I can run a tap across it and fix it up?
Old Jan 24, 2006 | 07:55 AM
earl's Avatar
Default Re: Messed up Eagle rod threads question.. (tgreaves)
I don't think it is a good idea to run a tap into a rod. Anything that changes the thread contour (as a tap would) is bad for the strength of the rod. You might try a thread chaser instead.
Not sure on the size and tp on that bolt. I will check.
Old Jan 24, 2006 | 10:40 AM
earl's Avatar
Default Re: Messed up Eagle rod threads question.. (earl)
Try a 3/8 24 chaser unless you have the early bolts
95JDM
Feb 4, 2008 07:39 PM
bluestreak_1
Nov 20, 2006 01:16 PM
CustomX113
Nov 12, 2006 05:53 PM
gotboostedvr6
Dec 30, 2005 05:27 AM
luckypon7
Jan 20, 2004 10:59 AM
