vacuum question
Old Jan 19, 2006 | 08:39 PM
Rev2 9K's Avatar
Default vacuum question
how much vacuum does a stock honda B series motor have at idle?
Old Jan 20, 2006 | 01:39 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: vacuum question (Rev2 9K)
I dont know specifically, but why would you need to know this?
Old Jan 20, 2006 | 06:52 PM
Rev2 9K's Avatar
Default Re: vacuum question (JDM_Ej)
because my car runs so rich it dies right away. I Check to see how much vacuum was present at idle, barely any, so I think since the map sensor is not seeing the vacuum it should have at idle, the ecu is loading the motor up on fuel.
Old Jan 21, 2006 | 09:31 AM
thesmogman's Avatar
You should have 16 to 22 in.Hg You have no vac present Wow! You have to have a major vac leak or your got holes in your pistons or valves not seating. But you say it starts, Hmmm. Vac leak somewhere. Can you borrow a smoke machine
That is automotive smk mach . You would cap off/seal the throttle body and blow the smoke into a vac port. Then look for leaks. That is the easiest way.
If no smk mach then just check all possible lines and IAC, PCV and all the gaskets
Cross your fingers and good luck!
Justinmnhall
22
Sep 6, 2013 03:40 PM
Topdawgg
Sep 2, 2013 05:03 AM
DA9teg93
May 9, 2005 12:12 PM
ferio 95
Jan 21, 2004 03:39 PM
