More B16 Problems
Old Jan 19, 2006 | 10:16 AM
SimplyTron's Avatar
Default More B16 Problems
To make a long story short: I had a B16 CRX, it got stolen, I got the B16 back, Headgasket was blown, put a new one on, and now I finally got it semi running. Whenever I give it gas it wants to bog out to the point of stalling, and takes a few seconds to recover back to a normal idle. Sometimes if I give it too much gas it stalls. It has fairly new plug wires that are intact, But when I pulled the plugs:
I think black means running rich but Im not sure. The guy that had it put an adjustable FPR on there and I dont know what its set at and dont have a gauge. I put new plugs in and it still bogs so it wasnt the plugs. Im running a stock virgin Pr3. Would running rich make it bog out like that? I have a stock FPR that I could put on, but Im not to sure how, so if theres a how to could you point me to it? I have to go to work now until very late so I wont be able to reply until maybe tomorrow but if you could try to help me before then thatd be great, thanks.
Old Jan 19, 2006 | 01:38 PM
eg6T's Avatar
Default Re: More B16 Problems (SimplyTron)
putting on the fpr is very simple,2 bolts and 2 lines i believe,just look at it and you will know how to do it
Old Jan 19, 2006 | 02:50 PM
1.7na's Avatar
SimplyTron,
I had a similar issue and it turned out that my cam gears were adjusted way off. Maybe check to make sure your cam gears are lined up - - and #1 is at TDC (white mark on pulley). Is your plug cover will fuel when you take them out?
HTH
1.7na
Old Jan 19, 2006 | 05:05 PM
SimplyTron's Avatar
Everything is at TDC, prety sure theres no fuel on the plugs. Im going to try to put the stock FPR on and see what happens. Could I try to adjust the FPR a little leaner and see if it doesnt bog then it its alright then change it out real quick? which way would I turn i?
Old Jan 20, 2006 | 10:20 PM
crdizzle6288's Avatar
Default Re: (SimplyTron)
my crx w/a b16 did the same thing.it could jus be mis firing which makes it bog out.i did everything from changing the spark plugs cap rotor and wires and still bogging.finally i changed the fuel injectors and it fixed my problem.or try some fuel injector cleaner.if it helps for a lil bit then goes back to the bogging then its ur fuel injectors cuz thats wat happened to mine.
Stray
Jun 19, 2007 08:07 AM
d15nonvtec
11
Apr 7, 2006 02:08 PM
MysteryWagon
Jul 20, 2002 01:46 AM
