94 civic sedan power window problem
Old Nov 16, 2010 | 07:09 PM
gerbsgsr's Avatar
Default 94 civic sedan power window problem
i have a 1994 civic sedan ex, i am having a problem with my master switch i had power to the drivers window only on the master switch but no power to the other doors but if you reach over and use the passenger switches they work just fine. now the drives one stopped working again this would be the second switch u have put in this car, do you think it would be the switch again or do you think it could be the motor this time. is there anything i can try to figure this out without spending money on a switch and a motor. do you know is there a way to manually roll up the window
Old Nov 16, 2010 | 07:11 PM
gerbsgsr's Avatar
Default Re: 94 civic sedan power window problem
please help me out here its getting kinda cold in the morning not being able to have the drivers window closed
Old Nov 17, 2010 | 05:49 AM
fcm's Avatar
fcm
Old Fart
You can check the motor at the switch plug, unplug and supply power and ground directly to the motor leads, should be red/yellow and red/blue, you can get power from the white/yellow, [drivers window power] and ground from the black lead.
If motor runs the switch is bad, if motor does not run it is either the motor or wiring to it. 94
Old Nov 17, 2010 | 06:19 PM
gerbsgsr's Avatar
okay thank you sir for the help ill try that as soon as i can thank you again
jasonblack
Honda Civic (2001 - 2005)
Aug 18, 2009 07:53 AM
da_ska
May 31, 2009 02:32 AM
marshun
May 21, 2007 10:11 PM
