another idle problem
Old Nov 12, 2010 | 03:59 PM
ef9itb's Avatar
Default another idle problem
i have 96 del sol with a gsr turbo...recently i have noticed my vacuum went from 21 to 12 and i cant get the car to idle..i have no check engine lights...wondering maybe could be a vacuum leak? other than idle it drives around pretty normal jus a richer air fuel reading...
Old Nov 12, 2010 | 06:21 PM
Hondaruss's Avatar
Default Re: another idle problem
sounds like vac. leak.... try getting some carb cleaner spray around all your connections to the intake maifold (injector bosses, TB, IAC, hoses, manifold to head,) if you spray and the engine changes tone everytime you spray you found a leak. also check the hose to the FPR since you mentioned its richer then normal
Old Nov 12, 2010 | 08:32 PM
dntnedvtec's Avatar
I am leaning towards a vac leak. Is it a high rpm, low rpm deal?
Old Nov 12, 2010 | 08:45 PM
torqen2k1's Avatar
Maybe you got the choke on? jk Yea sounds like a vacuum leak. Like Hondaruss said check with spraying starting fluid/ carb cleaner.
Old Nov 13, 2010 | 05:48 PM
ef9itb's Avatar
thanks guys...that carb cleaner worked...i have a hondata IM gasket...was leaking from there..i guess i need longer studs after putting that hondata gasket on because some of the bolts fell off...
Old Nov 14, 2010 | 05:26 AM
haukurn's Avatar
http://www.jspecautosports.com/files...chcenter3l.htm
PROJECT 91
Sep 25, 2009 11:18 AM
PhilMac
Jan 14, 2008 11:35 AM
Out of every "game"
Feb 8, 2006 01:12 PM
jdmlude_dude
Sep 10, 2005 05:38 PM
AkumaMax
Mar 14, 2003 08:43 AM
