B20 FUEL PRESSURE PROBLEM
Old Oct 28, 2010 | 12:11 PM
vpower101's Avatar
Icon3 B20 FUEL PRESSURE PROBLEM
hey ht, my ef sedan has been driving me crazy for a couple days now. last week i checked my fuel pressure and it was 55 psi with or with out vacuum about 10 psi to high. i figured the fuel pressure reg was bad so i ordered a b&m adjustable reg and guage and got a new regulator. last night i installed the new reg with b&m adjuster and guage. with the engine off the fuel psi can be adjusted to whatever,with no problem but with the engine running fuel psi cannot be adjusted it stays around 52 -60 psi. the car has a stock fuel system other than the b&m s**t.
if i turn the regulator to the lowest setting the car runs like crap,like it has low fuel psi but the gauge still says 52 psi!!!!! it seems like the gauge is bad but why does it work ok when the car is off??? any GOOD ideas?
Old Oct 28, 2010 | 01:13 PM
lsturbo33's Avatar
Default Re: B20 FUEL PRESSURE PROBLEM
I would think that the gauge is bad. There should be no fuel pressure with the car off. Where is the gauge mounted?
Old Oct 28, 2010 | 01:20 PM
2k.civic.si's Avatar
replace the gauge.
Old Oct 28, 2010 | 01:54 PM
vpower101's Avatar
the gauge is mounted on the fuel filter, and yes there will be fuel psi with the engine off if the fuel pump check valve is good it should hold psi for at least 5 minutes. i mean when the systen is primed with the engine off the gauge shows psi change when reg is adjusted
Old Oct 28, 2010 | 03:14 PM
vpower101's Avatar
bump
Old Oct 29, 2010 | 01:02 PM
vpower101's Avatar
bump
vpower101
Oct 30, 2010 03:44 PM
vpower101
Oct 29, 2010 06:57 PM
vpower101
10
Oct 29, 2010 02:36 PM
hondapowerb16a2
Mar 20, 2010 01:15 AM
Enig
Oct 29, 2004 04:48 AM
