need longer studs on head for intake manifold
Old Oct 31, 2010 | 01:19 PM
SLIM NOTHING's Avatar
Default need longer studs on head for intake manifold
the studs for the skunk2 intake manifold are short. i like to do things right, so i was wondering if anyone could point me in the direction to find longer ones with same threading, id like to get at least a half inch longer. i have a b18c1
for got to say i am using a hondata gasket also
Old Oct 31, 2010 | 04:05 PM
mouab18c1's Avatar
Default Re: need longer studs on head for intake manifold
Your OEM studs are short? I dont think skunk2 ships out studs with their IM. I've always used my OEM studs on any IM.
Old Oct 31, 2010 | 06:37 PM
nvr said skunk2 shipped out studs. some oem studs only allow the nut to grab a few threads not enough in my opinion when i have solid mounts, i want things right. i am also using a hondata gasket thats is thicker than oem
Old Oct 31, 2010 | 06:53 PM
mouab18c1's Avatar
Oh in that case seems like you already know it all. Goodluck
Old Oct 31, 2010 | 07:00 PM
Redline130's Avatar
You can use ARP stainless studs that are longer than OEM.
Old Nov 1, 2010 | 06:53 AM
fcm's Avatar
fcm
Old Fart
APR FTW... http://www.arp-bolts.com/ 94
Old Nov 1, 2010 | 08:16 AM
tofast4uh22's Avatar
the only reason you are having issues with the length of the studs is because of the hondata intake gasket. if you were using a stock gasket there wouldnt be a issue. if you are looking for a easy solution you can use the studs that the throttle body mount with on the intake manifold. they are longer and work perfect. so go to the junk yard and grab some. hope this helps
Old Nov 1, 2010 | 06:24 PM
uberEFtuner's Avatar
I bought some longer studs for my header from Advanced or Auto zone. I,m not sure if the intake is the same as exhaust.
Old Nov 1, 2010 | 06:53 PM
sc34dc4's Avatar
Yes both intake and exhaust use the same studs. They can be found at almost any hardware store. M8x1.25 and get them around 50mm since factory is 37mm. Mine were in a drawer labeled automotive studs and were $2.60 each. Advance Auto also sells them in a pack of 10 or 12 for $13. I just had to get some the other day for my blox manifold.
95skunkedgsr
15
Mar 21, 2011 12:54 PM
fizic
11
Mar 26, 2009 07:49 AM
EG2Driver
Jul 15, 2007 10:19 PM
WalkerGSR1
Sep 27, 2006 06:26 PM
hatchattak
Aug 11, 2004 09:48 AM
