Early rev limit
Old Nov 11, 2010 | 08:59 AM
95k20eg6's Avatar
Default Early rev limit
Alright guys I'm trying to help a buddy fix his car because it revlimits about 1500 rpms too early. I've searched and searched and came up with nothing that has fixed the problem. It's a pretty basic p30 pistons lsvtec on a chipped p28. So far we have changed out the ecu, dizzy, wires, plugs, iat sensor, speed sensor, cluster, injectors, fpr and nothin has changed. I'm up for any ideas.
Old Nov 11, 2010 | 01:14 PM
dntnedvtec's Avatar
Default Re: Early rev limit
What is the revlimit set to on the chip?
THat might be your problem there....
Old Nov 11, 2010 | 02:10 PM
1998GsRIntegra's Avatar
Its really unlikely for an oem cluster to read 1500rpm low. My jdm itr cluster reads about 300rpm high, which I dont mind. Your problem is probably in the chip. Thats about all thats left.
Old Nov 11, 2010 | 04:52 PM
95k20eg6's Avatar
I've used 3 different ecus, 2 chipped with 2 different redlines and one stock p30 and they it redlines about 1500 before each one is suppose to so that's not the problem.
Old Nov 11, 2010 | 07:46 PM
k!bye's Avatar
Go K, problems solvedddd Lol
Old Nov 11, 2010 | 08:10 PM
93egSLEEPER's Avatar
is it throwing any CELs?
Old Nov 11, 2010 | 09:20 PM
2k.civic.si's Avatar
Sounds to me like the tach is off. there is no way all 3 ecu's had a problem.
Old Nov 11, 2010 | 09:29 PM
DDTECH's Avatar
If this tuned on crome, if so, i have a map you can use and just burn it to your chip.. and u can thank me later.
Old Nov 12, 2010 | 07:01 AM
95k20eg6's Avatar
No cels, already thought of the tach that's why I changed the cluster out. And that would be great all motor but I don't have a chip burner.
Old Nov 12, 2010 | 08:58 AM
DDTECH's Avatar
I have a chip burner, and i can burn you a chip, it'll cost you but for 25.00 i dont think you'd really care.
Old Nov 12, 2010 | 03:40 PM
ericrx_88's Avatar
I had a similar problem redline at 6500 rpm it was in a 96 cx turned out to be the wiring from switching it over to obd1 vtec check your wires if you switch things over
Old Nov 14, 2010 | 08:12 PM
crazylilman's Avatar
if it was a engine swap it could be how the tranny is tuned. I know a si tranny revs around 8-9 where as a standard civic tranny revs at about 7-8. just throwing it out there i could be wrong.
Old Nov 15, 2010 | 07:34 AM
EJ1B18c's Avatar
Its either the tacho reading wrong ( i have seen some off by even 2000rpm)
or its a lack of fuel up high.
Old Nov 15, 2010 | 08:42 AM
HAMOTORSPORTS's Avatar
The transmission/ vss will not affect rev limit. The ECU only uses the VSS input to calculate fuel compensation for a given gear.
Old Nov 15, 2010 | 04:50 PM
LTCxD2B's Avatar
It could be the tune or the tranny i have a d16 tranny with d15b and before my tune it would rev only to 5 then i advanced the timing and fuel and it revs to 7 but the noise it made at redline was sharp and sounded like cracking and knock not like a rev limit
SetInMotion
Mar 29, 2009 06:05 AM
jdmvtecej2
Oct 27, 2008 04:46 PM
diM.
Apr 18, 2007 06:31 PM
prwil3030
11
Feb 16, 2007 08:30 AM
