No start(very strange)
Old Nov 27, 2010 | 12:10 PM
goforbroke's Avatar
MEAT PATTY
Default No start(very strange)
Okay yesterday I left my lights on all day at work, come outside and my battery is dead. Checked it with my ohmmeter and got 1.76 volts so yeah its completely dead. My coworker gave me a jump and I drove home(40 minute drive) and parked the car for the night. My coworker mentioned I should check the water level in my battery. Honestly I have never done that with any of my cars EVER.
So I come out this morning and my car starts on the first turn as usually. So I turn it off and check my water level in my battery and it was actually low. So I filled it to the correct line put the caps back on and the car wouldn't start now, not even turn over. Checked it with my ohmmeter again and the battery read 14.75 volts which surprised me considering I killed it yesterday. So I started checking my grounds and etc...... even tried jumping it.
So I took the battery out my sisters Altima and put it on my car and it started instantly. Her battery read 14.65 volts. So did my battery have a bad cell or did I destroy it when I put water in it? This has been bothering me trying to figure out what the hell I did wrong...
Old Nov 27, 2010 | 03:36 PM
fcm's Avatar
fcm
Old Fart
Default Re: No start(very strange)
Adding water to a batt. will not hurt it, my guess is either shorted cells or broken terminal, [one of the posts is not making contact inside the batt.] 94
Old Nov 27, 2010 | 04:27 PM
Scott_Tucker's Avatar
No battery should have 14.6 volts. Was this with the engine running?
Old Nov 27, 2010 | 05:37 PM
goforbroke's Avatar
MEAT PATTY
Umm that's a thought also, but its just weird how the car started earlier before I touched anything. I went over my grounds a few times and even cleaned them with sandpaper. All my connections were tight.
No the car was turned off when I took the reading and I took another reading when I removed the battery from the car. Both batteries were within very close voltage of each other, but my sisters battery instantly started my car.
Old Nov 28, 2010 | 04:13 AM
n5926g's Avatar
Batterys can show voltage,and have no current delivering capability.
As stated earlier...adding water likely had nothing to do with the failure.
Get a new one,and you should be good to go.
Old Nov 29, 2010 | 04:40 AM
goforbroke's Avatar
MEAT PATTY
Originally Posted by n5926g
Batterys can show voltage,and have no current delivering capability.As stated earlier...adding water likely had nothing to do with the failure.
Yeah I knew it was my battery after I tried my sisters. I'm just more curious as to what happen to the battery. Probably just going to chalk it up as having a bad cell. Battery had a ship date of 2005 so it was probably on the verge of going pretty soon.
Old Jan 15, 2011 | 05:59 PM
JaredH's Avatar
My advice would be to just hook a lead up to your sisters car and have her drive behind you wherever you go. then you don't have to buy a new battery and you can use the money you saved to pay for a tank of gas and come hang out. when you get here i will taser you while you are using the toilet by sneaking in to the bathroom through a secret door that is disguised as a wooden wall. i hope this satisfies the (very strange) portion of your thread title.
W O T
May 8, 2007 11:38 PM
W O T
May 8, 2007 10:36 AM
4DRmafia
24
Jun 25, 2004 05:59 PM
GsR HtCh
Mar 2, 2004 08:12 AM
Renegade
May 21, 2002 01:20 PM
