3m windo-weld
Old Oct 29, 2010 | 06:12 PM
James777's Avatar
Default 3m windo-weld
i have an 03 rsx type s with energy suspension motor mount inserts installed and am wanting to cut down on vibration in the car. i've read about people using windo-weld to fill the mounts and wanted to know if there will be a noticeable difference between the two. also how many tubes do i need to get? the inserts are installed in two mounts on this particular car.
Thanks,
Old Oct 29, 2010 | 08:16 PM
wtf_is_jdm's Avatar
Default Re: 3m windo-weld
If I am not mistaken..... I believe that the 3M window weld would actually increase the overall rigidness and thus creating more vibration..... Any comments from HT members that have used the product seeing as I have not?
Old Oct 29, 2010 | 11:42 PM
James777's Avatar
i have the black inserts if that matters.
thanks,
Old Nov 2, 2010 | 03:20 PM
Rigginit's Avatar
3M is extremely rigid without going fully solid. Mine has the 3 Motor mounts as a stock set and the 2 Torque mounts are window weld. perfect for me. Don't think I would like the 3m in all mounts due to how stiff it came out on the torques.
Old Nov 2, 2010 | 03:30 PM
James777's Avatar
what about the polyurethane that you get from home depot?
Old Nov 2, 2010 | 04:26 PM
bauergold's Avatar
Making the mounts stiffer will not help with vibrations.
Old Nov 2, 2010 | 05:43 PM
Rigginit's Avatar
Same deal on the poly from the depot. All great if you're looking to stiffen. Not so much for your needs as you describe. Would most likely be best to revert to OEM style mounts.
Old Nov 4, 2010 | 11:57 AM
James777's Avatar
thanks,
alx_90ef
20
May 30, 2014 06:31 AM
flangemastermike
Nov 24, 2007 04:55 PM
NAmodified
Oct 16, 2007 08:35 AM
white_db8
May 26, 2007 09:34 AM
Bbasso
Mar 4, 2005 05:48 PM
