bottom end gasket question
Old Nov 27, 2010 | 11:06 AM
sh!ft's Avatar
Who the fack changed my title?!
Default bottom end gasket question
im going to be running the gsr oil pan as well as the oil pickup tube from a gsr on my ls block. besides the oil pan gasket, rear main seal, water pump gasket, oil pump gasket, what other gaskets should i get? this is from head gasket down. does the oil pickup even require a gasket when mating to the block,oil pump?
Old Nov 27, 2010 | 09:03 PM
HAMOTORSPORTS's Avatar
Default Re: bottom end gasket question
All of the bottom end gaskets will be interchangeable other than water pump gaskets. Use hondabond where the oil pump mates to the block (and use the small o-ring where the oil outlet is) as well as the rear main seal housing..
Old Nov 28, 2010 | 11:30 AM
sh!ft's Avatar
which oil outlet?
Inextricabledrvr
May 15, 2009 08:03 PM
keychild486
Mar 2, 2009 12:07 PM
O16581724 5 2 5
Jun 23, 2005 07:07 PM
Jonathan_ED3
Apr 11, 2003 09:02 PM
