B-series ef not starting
Old Nov 7, 2010 | 10:14 PM
spoon.ef9's Avatar
Default B-series ef not starting
K..so swapped in a first gen obd-0 b16 in my ef, tried starting it and its a no go.
-previous d-series ran perfect
-mpfi done
-brand new dizzy
-reused spark plugs and wires
-reused obd0 injectors with resistor box
-new obd0-obd1 conv. harness
-obd1 p72
-vtec not hooked up yet
Weird thing is while i was checking for spark the engine started... And if i tried putting the plug and wire in the cyl it would die out...
Diagnosed:
-different dizzy
-chked for spark
-set motor to tdc, took cap off dizzy, rotor is facing bottom left
-sparkplug timing order
34
12
-injectors work fine
- fpr gauge reads 40psi
Any suggestions!!!!????
Old Nov 8, 2010 | 07:36 AM
The-obd0-one's Avatar
Default Re: B-series ef not starting
define wont start do you mean the stater isnt kicking on or is it spining over with no signs of running
Old Nov 8, 2010 | 01:30 PM
spoon.ef9's Avatar
the starter works cause it starts on 3 cyl but when all four sparkplugs are in it would crank then catch for a sec and die out...
Old Nov 8, 2010 | 05:06 PM
LSVTECEF91's Avatar
LMAOL...OBD0-OBD1 jumper.....hahahaha stick with all obd0...ur ecu is >obd1<...distributor can't be 0 with that obd1 ecu and resister box is only for obd0 you need the obd 0 ecu...i also got one...lol if you want to buy ask...but like i said change that ecu to 0
Old Nov 8, 2010 | 07:24 PM
kantspell's Avatar
check your cam timing dude...dosnt make sense how it dies when you have only 3 spark plugs in...
Old Nov 8, 2010 | 11:11 PM
spoon.ef9's Avatar
dizzy is fine..its a t44u (obd1)
I set everything to tdc and the motor was never takin apart either...it starts on 3cyl but not with all sparkplugs/wires in. I've checked all the timing, plugs and wires are good..im hookin up my oil pressure gauge tmo to see if im getting any pressure.
Old Nov 9, 2010 | 05:18 AM
kantspell's Avatar
check for any codes. where is the map sensor hooked up to? be sure it is not ported vac it needs to be after the throttle body.
Old Nov 9, 2010 | 11:21 AM
spoon.ef9's Avatar
its hooked up @ the top of the tb..not exactly sure how to chk for codes..ecu doesnt have light
Old Nov 9, 2010 | 01:37 PM
kantspell's Avatar
there should be a two wire plug on the passenger side of the car under the dash in a green rubber cover thing. when you find it turn the car on try to start it then leave the key on run. jumper the two wires with a paper clip or something. the check engine light will flash.
ps just for diag take move the map to the fuel pressure regulator vac port on the manifold try to start it like that
Old Nov 13, 2010 | 03:32 AM
spoon.ef9's Avatar
havent been able to try that yet but i have an oil light on..so im gonna chk the oil sensor..but its weird that it still runs on 3 cyl...
spoon.ef9's Avatar
oh and is that two wire plug on ef's as well?
Old Nov 16, 2010 | 06:33 AM
kantspell's Avatar
yes it does, have you fixed this car yet?
Old Nov 17, 2010 | 09:47 PM
spoon.ef9's Avatar
k..tried that, and also tried starting it with oil cap off(thinking maybe too much crankcase press.)..so im gonna try 2 more things..compression test an reset timing and if that doesnt wrk im gonna blow the car up..ne other suggestions?
Old Nov 17, 2010 | 10:40 PM
spoon.ef9's Avatar
oh and i tried to jump that plug by using a paperclip, one end on each end and key in 2 pos..the light just stays on
Old Nov 19, 2010 | 04:50 PM
spoon.ef9's Avatar
will update after compression test
Old Nov 20, 2010 | 06:13 AM
kantspell's Avatar
o and try to start the car then dont turn the key off check for codes again. because every time you turn the key off it clears the codes
Old Nov 20, 2010 | 10:18 AM
tagperformance's Avatar
Sounds like your firing order is off, Check timing and firing order.
Old Nov 21, 2010 | 02:42 PM
spoon.ef9's Avatar
kantspell- waiting on a friends ecu..under the impression its just my ecu thats fukt
tagperformance-checked timing(first post)..but I cant use the timing light unless the car is running right..
Old Nov 23, 2010 | 07:44 PM
spoon.ef9's Avatar
So a p28 dint change anything...last thinh I can think of is the conv. Harness..
Old Nov 24, 2010 | 12:56 PM
kantspell's Avatar
your missing something.
how did the comp test go?
Old Nov 24, 2010 | 04:27 PM
spoon.ef9's Avatar
havent been able to get a hold of one yet
Old Nov 26, 2010 | 01:42 PM
spoon.ef9's Avatar
suggestions?
vw40life
Apr 20, 2012 05:09 PM
BoostinTEG
Sep 1, 2011 06:46 AM
noremorseracing
Dec 6, 2009 01:29 PM
clubef9
Apr 16, 2007 03:22 PM
Cimburke23
33
Sep 1, 2006 05:59 PM
