Fuel system
Old Nov 28, 2010 | 05:59 AM
LS/V-T's Avatar
Icon2 Fuel system
What are the whp/wtq limits of the stock fuel system on a 96-00 civic?
I am mostly curious how much power can be made before needing to upgrade the fuel line it's self.
Old Nov 28, 2010 | 11:46 AM
mouab18c1's Avatar
Default Re: Fuel system
Fuel lines are fine its more of upgrading your fuel pump and fuel injectors.
Old Nov 28, 2010 | 07:53 PM
LS/V-T's Avatar
So there not really any reason to use larger fuel line?
Old Nov 28, 2010 | 08:16 PM
mouab18c1's Avatar
Honestly i've never head anyone using larger fuel lines. Larger fuel lines does not mean more fuel. Thats controlled by the ecu.
Old Nov 28, 2010 | 08:31 PM
mtber's Avatar
The only reason you would need to upgrade your fuel system is if your engine is requiring more fuel then your fuel system can supply. The stock fuel lines can handle around 500-600 whp on c16 fuel using a single walbro 255 lph fuel pump and 1000cc injectors.
Old Nov 30, 2010 | 02:09 PM
Ljoshlun's Avatar
Icon3 Re: Fuel system
The capacity of the fuel pump and the Fuel Pressure Regulator will control the pressure at the fuel injectors. Larger fuel line would not make the Fuel Pressure Regulator maintain any different pressure, niether will it increase the capacity of the fuel pump.
Enjoy..
Dominic-CTR
Oct 24, 2004 04:08 AM
Bantam
Mar 7, 2003 08:58 AM
Hispeed
Jul 30, 2001 10:12 AM
