Oil Leak issue
Old Oct 28, 2010 | 06:39 PM
guy_from_nerk's Avatar
Default Oil Leak issue
Heres the story, I have 844 miles on my built setup (built by Laskey). I noticed after having the car tuned that when I hit higher rpms, there will be oil sitting on my rear motor mount. At first I thought maybe my block fittings for catch can were loose/leaking, so I teflon taped those and re-tightened them. Took car out and got on it a bit, same results. So I checked to see if maybe my oil filter was loose, checked all my intake manifold bolts, everything is tight.
I have sprayed the engine bay down and wiped everything off trying to find the culprit for the leak, still cant figure out exactly whats causing the oil to be on the rear motor mount
I am hoping like hell its not my headgasket (cometic), but have a sick feeling that it might be. The car doesn't over heat or anything so I know its not a blown headgasket causing this....any one have any ideas?
jmccalip
Dec 22, 2012 09:02 AM
Honda_Si21
12
Mar 27, 2011 08:40 PM
bboixtc
Mar 25, 2008 04:24 PM
92redhatch
Aug 27, 2006 09:52 AM
belkins
Feb 17, 2005 10:17 AM
