HELP: heater isnt working
Old Nov 24, 2010 | 11:47 PM
SPOON_BeIgHtEeNsEe's Avatar
Default HELP: heater isnt working
car 1997 honda crv... engine gets up to temp (reads half on gauge)
well winter is HERE (DAMMIT!!!!!!!!) and its SUPER cold... my damn heater isnt working... i flushed the coolant and still doesnt work... i even shoved the garden hose into the coolant lines (line that goes to the heater core box, two lines on the firewall) and it returned fine so i dont think its clogged... it does turn on but blows nothing but COLD AIR!!!! what can it be? i need heat in the crv because the odyssey isnt cutting it in the snow tho it does have heat
also the coolant line from the head to the switch (piece that lets the coolant pass thru) gets hot but from the switch back the coolant line is cold and also the return line... could it be its not circulating..
Old Nov 25, 2010 | 05:52 AM
fcm's Avatar
fcm
Old Fart
Default Re: HELP: heater isnt working
MM&Y of car???? 94
Old Nov 27, 2010 | 02:43 PM
someone? anyone????? HELP its damn cold
Old Nov 27, 2010 | 03:29 PM
fcm's Avatar
fcm
Old Fart
Check the water valve, #1... http://www.hondaautomotiveparts.com/...y5=WATER+VALVE make sure it opens and closes when you move the temp. control, it may be a broken or disconnected cable or the valve itself is bad. 94
Old Nov 27, 2010 | 03:31 PM
Project H's Avatar
I just went threw this problem and it was the track for the hot cold had came off track. Is it hard to slide the hot cold back and forth and do you hear it kicking in?
Old Nov 28, 2010 | 11:47 AM
well when drained the coolant i checked the valve and open/closed fine...
hot and cold switches fine... **** moves freely and it kicks when u switch it... im thinking its either that valve and its my coolant system
Old Nov 29, 2010 | 06:10 AM
fcm's Avatar
fcm
Old Fart
You said, "also the coolant line from the head to the switch (piece that lets the coolant pass thru) gets hot but from the switch back the coolant line is cold and also the return line... could it be its not circulating" that would indicate the valve is not working or there is air in the system, "air-lock".
When you move the temp. control does the valve arm move? 94
Old Nov 29, 2010 | 06:44 AM
Crxlsturbo's Avatar
If your heater is not working. Then your heater core went out. Never mind checking your coolent and other stuff. Your heater core is out. Mine is super cold in my 99 civic lx. To replace it you have to pull out some of the dash. Its right behind it.
Old Nov 29, 2010 | 10:06 AM
cable pulls it fine... i also removed that valve, opend it manually and it also opens and closes fine...
Old Nov 29, 2010 | 11:27 AM
fcm's Avatar
fcm
Old Fart
Air-lock, or water pump. 94
Old Dec 4, 2010 | 12:54 PM
Project H's Avatar
No bs theres 2 tracks that run under your dash that slide one was off on mine and caused this problem i did everything from new thermostat to flush the system and heater core.you can see the tracks from the passenger side i mean its worth a shot to look at it.
Sheraizzle
Aug 16, 2016 12:27 PM
SPOON_BeIgHtEeNsEe
Honda CR-V & Element
Nov 30, 2010 01:54 PM
Hardedge
Jan 8, 2008 05:59 PM
ColMustard
Jan 5, 2008 10:34 PM
ScottEK
Oct 30, 2002 09:42 PM
